Dual switch (not stacked) in a rack with bonded server NICs
EB_Tech
I've got 2 switches in a rack with a trunk connection between them. The servers have 4 NICs with a bond0 for NIC1&3 and bond1 on NICs 2&4.
NICs 1&2 are on switch 1 and NICs 3&4 on switch 2.
Firewall gateway (out of my control) is at xx.xx.3.1
VLANs/SVIs         1                  2                  3
Switch 1       xx.xx.3.2   xx.xx.4.1     xx.xx.5.1
Switch 2       xx.xx.3.3   xx.xx.4.2     xx.xx.5.2
Switches have route 0.0.0.0 0.0.0.0 xx.xx.3.1 (to the firewall)
Bond0   xx.xx.3.x
Bond1   xx.xx.4.x
So what should the gateway be for the different bonds on the NICs to ensure redundancy? I could make it the firewall but then if the firewall ever changes I would need to change every NICs gateway.
For example, if switch 1 goes down and bond0 is pointing to xx.xx.3.2 will it still get out to the firewall when the bond is now only connected to Switch 2 through NIC 3?
It's my understanding that the bond will failover but is it smart enough to know the gateway is to a different VLAN/SVI and then to the firewall? Or is there a way in linux to have a backup gateway or maybe leave the gateway empty?
Any help is appreciated. I'm still learning and networking is not my main area of expertise lol.
Edit:
2x Cisco C9300
Attached basic layout pdf
balaji.bandi
i would advise deploying HSRP on the switch for redundancy
BB
post a schematic drawing of your topology, showing how your devices are connected. Is the redundant firewall already in place, or is that a fiuture option ? Also, what type/model switches do you have ?
Just attached a pdf of the layout.
The firewall is for remote access into the systems. I'm only responsible for the rack itself with the 2 C9300 switches and servers.
