10-28-2009 07:49 AM - edited 03-06-2019 08:21 AM
When I update the access-list used in a route-map used for a policy-route on my Cat 4507R 12.2(53)SG, there's a significant delay between when I update the ACL and when the change takes affect.
I'm guessing it has somthing to do with a certain table timing out? What's causing this delay? I'm trying to troubleshoot a couple changes I recently made to a route-map and the delay is killin me. :P Thanks.
Solved! Go to Solution.
10-28-2009 07:57 AM
Hello Ryan,
changes to the ACL need to be propagated to TCAM table programming.
I would suggest to try to use a different ACL and then to make a change invoking the new ACL.
the overall process may be faster then waiting for an update of the TCAM table.
if you use a new ACL you are making a config change that should trigger a new calculation of TCAM.
it is enough to alternate two different ACLs you don't need to use a new one at each change.
Hope to help
Giuseppe
10-28-2009 07:57 AM
Hello Ryan,
Hope to help
Giuseppe
10-28-2009 08:00 AM
Thanks. I figured it was somthing simple like that. I just couldn't remember which table it was that had to be updated. Thanks Giuseppe! A true asset to NetPro boards :)
