Duplex settings
swestrich
what kind of duplex settings do I have to make in order to have no duplex missmatch between sw-100001# fa0/18 and a nother switch with sw-100004# gigabitEthernet 1/0/1. When I do auto/auto I have perfomance probelms that look like duplex missmatch:
When I do duplex full the connection is not coming up?
Any Idears?
Best regards
Sascha
Loading c2960-lanbasek9-mz.150-2.SE6.bin from 53.92.228.13 (via Vlan317): !.!.!.!.!.!.!.!.!.!.!.!.!.!.!..!.!.!.!.!.!.!.!.!.!.!.!.!.!.!..!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!..!.!.!.!.!.!.!.!.!.!.!..!.!.!.!.!.!.!..!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!..!.!.!.!.!.!.!.!.!.!.!.!.!.!.!..!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!..!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!.!..!.!.!.!.!.!.!.!.!.!.!.!.!.!.!..!..!.!.!.!.!.!.!.!.!.!.!.!.!...
sw-100004#sh int gigabitEthernet 1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is c414.3c50.9601 (bia c414.3c50.9601)
  Description: to Sw100001 0/18
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 151/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:01, output hang never
  Last clearing of "show interface" counters 03:44:16
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 731000 bits/sec, 39 packets/sec
  5 minute output rate 33000 bits/sec, 37 packets/sec
     476758 packets input, 1055732145 bytes, 0 no buffer
     Received 53260 broadcasts (48128 multicasts)
     0 runts, 295 giants, 0 throttles
     398372 input errors, 123485 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 48128 multicast, 0 pause input
     478247 packets output, 53981482 bytes, 0 underruns
I would set both devices to
speed 100
duplex full
Richard
thats what I tought, but this is whats happend:
Fa0/18    to 10004 0/1       notconnect   trunk        full   auto 10/100BaseTX
set speed to 100, moment sent to auto
glen.grant
    Get a crossover cable and  set both interfaces with "no mdix auto " .
