12-15-2022 11:42 AM
Hello community!!
I have a problem with 2 Cisco Catalyst 9300 in stack.
When I create the interface vlan 16 and the interface vlan 22, both interface have the same mac address.
I workaround the situation, setting the mac addres under the interface command, but I would like to know if this behavior is a bug or not. Really I need fix it.
I make a test with another catalyst 9300 and the situation was the same.
Anyone, can you help me with it?
12-15-2022 12:02 PM
Having the same MAC address for multiple SVIs should not be an issue. For more info refer to this document:
12-15-2022 12:03 PM
have not see this problem any time before.
1. if this stack - check the stack ring having any issue.
2. check the SN again cisco inventory
or may be bug, update to 17.64 and check
