ā06-14-2017 12:22 AM - edited ā03-08-2019 10:58 AM
Hello community,
I did not find really reliable information if the tunable DWDM SFP+ (DWDM-SFP10G-C) is supported in the Cat4500 Sup7-E. I only found the information in the compatibility matrix that DWDM SFP+ are supported since Version 3.5.0E. Does someone know if the special tunable transceiver DWDM-SFP10-C works in the Sup7-E of the Cat4500?
Thank you very much in advance,
Marco.
ā06-14-2017 12:31 AM
I only see it supported under the ASR models in the matrix sheet , and the 6800 with the non -c version , I dont see 4500s supporting them at all
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
ā06-14-2017 12:47 AM
Hello Mark,
thanks for your fast answer. The transceiver matrix is inconsistent with the DWDM-SFP10G-C. It is not listed at all in the global section SFP+ or DWDM SFP+. Only under the ASR models as you have written. In the section of the Cat4500 is the following list:
WS-X4712-SFP+E |
SFP-10G-SR |
3.1.0SG |
3.1.0SG |
SFP-H10GB-CU1M |
ā |
3.1.0SG |
SFP-10G-ER |
3.2.0SG |
3.2.0SG |
DWDM SFP+ |
3.5.0E |
3.5.0E |
SFP-10G-BXD-I |
3.8.0E |
3.8.0E |
SFP-H10GB-CU1-5M |
ā |
3.6.0E |
So does the DWDM-SFP10G-C belong to the group "DWDM SFP+" ??? Are there commands in the cli available to tune the wavelength?
Best regards,
Marco.
ā06-14-2017 01:32 AM
Going by this doc it looks to be part of the SFP+ alright bottom of the ordering list , this is specific doc for DWDM SFP+
regarding configuring it I haven't got these in operation , what software do you have on it you can check that specific config guide on the Cisco website for that version and all related commands that are available
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/dwdm-transceiver-modules/data_sheet_c78-711186.html
Table 4. Cisco DWDM SFP+ Ordering Information
Product Number |
DWDM-SFP10G-60.61= |
10GBASE-DWDM 1560.61 nm SFP+ (100-GHz ITU grid) |
21 |
DWDM-SFP10G-57.36= |
10GBASE-DWDM 1557.36 nm SFP+ (100-GHz ITU grid) |
25 |
DWDM-SFP10G-53.33= |
10GBASE-DWDM 1553.33 nm SFP+ (100-GHz ITU grid) |
30 |
DWDM-SFP10G-49.32= |
10GBASE-DWDM 1549.32 nm SFP+ (100-GHz ITU grid) |
35 |
DWDM-SFP10G-45.32= |
10GBASE-DWDM 1545.32 nm SFP+ (100-GHz ITU grid) |
40 |
DWDM-SFP10G-41.35= |
10GBASE-DWDM 1541.35 nm SFP+ (100-GHz ITU grid) |
45 |
DWDM-SFP10G-37.40= |
10GBASE-DWDM 1537.40 nm SFP+ (100-GHz ITU grid) |
50 |
DWDM-SFP10G-33.47= |
10GBASE-DWDM 1533.47 nm SFP+ (100-GHz ITU grid) |
55 |
DWDM-SFP10G-C |
10GBASE-DWDM tunable SFP+ (50-GHz ITU grid) |
See Table 3 |
