dynamic desirable mode
fran19422
Hello, on a 2960 switch, is the default switchport mode 'dynamic desirable' ?
How can I see what the swtichport mode is. When I do a 'show run' nothing regarding switchport modes is visible ?
Thanks for any help.
johnlloyd_13
Level 9
Level 9
Yes, it's the default switch port setting. Cisco device IOSs normally don't display the default setting/command in the show run.
Issue a 'show interface x/x switchport' command to verify on which mode it's in.
mhnedirli
hi, you can use show int status  this is shows all interfaces status
nkarthikeyan
Level 7
Level 7
Hi Philip,
John is correct.
sh interfaces switchport brief
It will show an output like the below
Port        Status     Op.Mode  Op.Encap Channel-id Vlan
Te1/1       connected   trunk    802.1q   --          201,207
Te1/2       connected   trunk    802.1q   --          201,207
Te1/3       disabled    none     native   --          201
Gi2/1       notconnect  none     native   --          201
Gi2/2       notconnect  none     native   --          201
Gi2/3       connected   access   native   --          201
Please do rate if the given information helps.
By
Karthik
