Dynamic routing issue
Bruno Silva
well, my question is: I have one central route (Cisco Catalyst 3750G-48TS-S) and twenty Switch with layer three ios (Cisco 3560G-24) conected in star topology....
What i want to know is, how central router can communicate with just another router (Cisco 1841) that is behind any 3560G layer three switch?
the cisco 1841 is always the same router that could be behind any other cisco 3560G switch.
Thanks a lot for your patience!
Bruno
107 Replies 107
Jon Marshall
Bruno
It depends on how the 3560s are connected to the core switch.
Are they routing and connected with L3 routed ports or is all the routing done on the core switch and the 3560s are connected using L2 trunks ?
Jon
Jon,
the 3560G switches are connected to the central router 3750G by a troncal with dedicated vlan. Each 3560G switch it's connected with a specific vlan.
It's all connected with L3 routed ports.
Am i understanding?
Thanks a lot Jon!
Bruno
troncal ?? - don't know what that is, do you mean trunk ?
The following doesn't make sense -
The above two statements contradict each other.  Do you mean there is only one vlan per switch and that the switch then uses a routed port to connect back to the core.
Can you post a "sh ip route" from the core switch and one of the other 3560s ?
Jon
Sorry, Jon
I'm Portuguese and sometimes i have to speak spanish and i'm confusing some words... sorry about that. What i want to mean was backbone....
CISCO 3750 x 1
interface Loopback0
ip address 10.0.0.1 255.255.255.255
ip pim sparse-mode
interface Loopback1
ip address 10.1.1.1 255.255.255.255
ip pim sparse-mode
interface Port-channel1
no ip address
interface Port-channel1.30
description VLAN_INTEGRACAO_1
encapsulation dot1Q 30
ip address 10.210.0.2 255.255.255.248
interface Port-channel1.31
description VLAN_INTEGRACAO_2
encapsulation dot1Q 31
ip address 10.210.0.18 255.255.255.248
interface Port-channel1.201
encapsulation dot1Q 201
ip address 10.10.10.2 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.202
encapsulation dot1Q 202
ip address 10.10.10.10 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.203
encapsulation dot1Q 203
ip address 10.10.10.18 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.204
encapsulation dot1Q 204
ip address 10.10.10.26 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.205
encapsulation dot1Q 205
ip address 10.10.10.34 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.206
encapsulation dot1Q 206
ip address 10.10.10.42 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.207
encapsulation dot1Q 207
ip address 10.10.10.50 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.208
encapsulation dot1Q 208
ip address 10.10.10.58 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.209
encapsulation dot1Q 209
ip address 10.10.10.66 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.210
encapsulation dot1Q 210
ip address 10.10.10.74 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.211
encapsulation dot1Q 211
ip address 10.10.10.82 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.212
encapsulation dot1Q 212
ip address 10.10.10.90 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.213
encapsulation dot1Q 213
ip address 10.10.10.98 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.214
encapsulation dot1Q 214
ip address 10.10.10.106 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.215
encapsulation dot1Q 215
ip address 10.10.10.114 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.216
encapsulation dot1Q 216
ip address 10.10.10.122 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.217
encapsulation dot1Q 217
ip address 10.10.10.130 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.218
encapsulation dot1Q 218
ip address 10.10.10.138 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.219
encapsulation dot1Q 219
ip address 10.10.10.146 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.220
encapsulation dot1Q 220
ip address 10.10.10.154 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.230
encapsulation dot1Q 230
ip address 10.10.10.162 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Port-channel1.500
description VLAN_WIMAX_MANAGEMENT
encapsulation dot1Q 500
ip address 10.10.50.49 255.255.255.0
no ip mroute-cache
interface Port-channel1.555
description VLAN_RADIO_MANAGEMENT
encapsulation dot1Q 555
ip address 10.200.20.2 255.255.255.0
standby ip 10.200.20.1
standby priority 140
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type rj45
no negotiation auto
channel-group 1
interface GigabitEthernet0/1
no ip address
ip pim sparse-mode
duplex auto
speed auto
media-type rj45
no negotiation auto
channel-group 1
interface GigabitEthernet0/2
no ip address
ip pim sparse-mode
no ip mroute-cache
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/2.10
description VLAN_DADOS
encapsulation dot1Q 10
ip address 192.168.120.1 255.255.255.0
ip pim sparse-mode
interface GigabitEthernet0/2.11
description VLAN_MANAGEMENT
encapsulation dot1Q 11
ip address 10.2.120.1 255.255.255.0
ip pim sparse-mode
interface GigabitEthernet0/2.12
description VLAN_VOICE
encapsulation dot1Q 12
ip address 192.168.121.1 255.255.255.0
ip pim sparse-mode
interface GigabitEthernet0/2.13
description VLAN_PRINTERS
encapsulation dot1Q 13
ip address 192.168.122.193 255.255.255.192
interface GigabitEthernet0/2.14
description VLAN_BACKUP
encapsulation dot1Q 14
ip pim sparse-mode
interface GigabitEthernet0/2.15
description VLAN_RED_FW
encapsulation dot1Q 15
ip pim sparse-mode
interface GigabitEthernet0/2.17
description MNG_FW
encapsulation dot1Q 17
ip address 192.168.122.1 255.255.255.192
interface GigabitEthernet0/2.18
description RED_GNR
encapsulation dot1Q 18
ip address 192.168.220.1 255.255.255.0
interface GigabitEthernet0/2.550
description VLAN_SERVER_MANAGEMENT
encapsulation dot1Q 550
ip address 10.10.20.1 255.255.255.0
interface POS1/0
no ip address
encapsulation ppp
crc 32
clock source internal
pos framing sdh
pos scramble-atm
router eigrp 1
network 10.10.10.0 0.0.0.7
network 10.10.10.8 0.0.0.7
network 10.10.10.16 0.0.0.7
network 10.10.10.24 0.0.0.7
network 10.10.10.32 0.0.0.7
network 10.10.10.40 0.0.0.7
network 10.10.10.48 0.0.0.7
network 10.10.10.56 0.0.0.7
network 10.10.10.64 0.0.0.7
network 10.10.10.72 0.0.0.7
network 10.10.10.80 0.0.0.7
network 10.10.10.88 0.0.0.7
network 10.10.10.96 0.0.0.7
network 10.10.10.104 0.0.0.7
network 10.10.10.112 0.0.0.7
network 10.10.10.120 0.0.0.7
network 10.10.10.128 0.0.0.7
network 10.10.10.136 0.0.0.7
network 10.10.10.144 0.0.0.7
network 10.10.10.152 0.0.0.7
network 10.10.10.160 0.0.0.7
network 10.10.50.0 0.0.0.255
network 10.0.0.0
network 192.168.2.0
network 192.168.120.0
network 192.168.121.0
network 192.168.122.192 0.0.0.63
network 192.168.220.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.2.254
ip route 10.26.8.0 255.255.255.0 192.168.2.254
ip route 10.200.0.0 255.255.0.0 10.200.20.16
ip route 192.168.2.0 255.255.255.0 192.168.120.254
ip route 192.168.125.0 255.255.255.0 10.10.10.163
ip route 192.168.126.0 255.255.255.0 10.10.10.163
ip route 192.168.127.0 255.255.255.0 10.10.10.163
ip route 192.168.130.0 255.255.255.0 10.10.10.113
ip route 192.168.131.0 255.255.255.0 10.10.10.121
ip route 192.168.132.0 255.255.255.0 10.10.10.129
ip route 192.168.133.0 255.255.255.0 10.10.10.137
ip route 192.168.134.0 255.255.255.0 10.10.10.153
ip route 192.168.135.0 255.255.255.0 10.10.10.145
ip route 192.168.136.0 255.255.255.0 10.10.10.57
ip route 192.168.137.0 255.255.255.0 10.10.10.49
ip route 192.168.138.0 255.255.255.0 10.10.10.33
ip route 192.168.139.0 255.255.255.0 10.10.10.41
ip route 192.168.140.0 255.255.255.0 10.10.10.9
ip route 192.168.141.0 255.255.255.0 10.10.10.1
ip route 192.168.142.0 255.255.255.0 10.10.10.17
ip route 192.168.143.0 255.255.255.0 10.10.10.25
ip route 192.168.152.0 255.255.255.0 10.10.10.81
ip route 192.168.153.0 255.255.255.0 10.10.10.73
ip route 192.168.154.0 255.255.255.0 10.10.10.65
ip route 192.168.155.0 255.255.255.0 10.10.10.89
ip route 192.168.156.0 255.255.255.0 10.10.10.97
ip route 192.168.157.0 255.255.255.0 10.10.10.105
ip route 192.168.225.0 255.255.255.0 10.10.10.163
ip http server
ip pim rp-address 10.0.0.1
ip msdp peer 10.1.1.2 connect-source Loopback1
ip msdp redistribute list 111
ip msdp originator-id Loopback1
CISCO 3560G x 20
description Digi
switchport access vlan 115
switchport mode access
description Codec
interface GigabitEthernet0/3
description Switch_Torre
interface GigabitEthernet0/4
description Servidor
interface GigabitEthernet0/5
description Wimax
switchport trunk allowed vlan 500-508
switchport mode trunk
interface GigabitEthernet0/6
interface GigabitEthernet0/7
description PC_Operador
interface GigabitEthernet0/8
interface GigabitEthernet0/9
description Telefone_Operador
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
description CCTV1
interface GigabitEthernet0/15
interface GigabitEthernet0/16
description CCTV2
interface GigabitEthernet0/17
interface GigabitEthernet0/18
description CCTV3
interface GigabitEthernet0/19
interface GigabitEthernet0/20
description CCTV4
interface GigabitEthernet0/21
description Central_Alarmes
switchport block multicast
interface GigabitEthernet0/22
description Intercomunicador
interface GigabitEthernet0/23
description Central_Acessos
interface GigabitEthernet0/24
description ALCATEL
switchport trunk allowed vlan 215,500
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
interface Vlan115
description SEGMENTO_PO
ip address 192.168.130.1 255.255.255.0
ip pim sparse-mode
no ip mroute-cache
interface Vlan215
description SEGMENTO_CCC
ip address 10.10.10.113 255.255.255.248
ip pim sparse-mode
no ip mroute-cache
interface Vlan500
description VLAN_WIMAX_GESTION
ip address 10.10.50.43 255.255.255.0
interface Vlan501
description WIMAX_UM1
ip address 10.10.51.16 255.255.255.0
ip pim sparse-mode
no ip mroute-cache
interface Vlan502
description WIMAX_UM2
ip address 10.10.52.16 255.255.255.0
ip pim sparse-mode
no ip mroute-cache
interface Vlan503
description WIMAX_UM3
ip address 10.10.53.16 255.255.255.0
ip pim sparse-mode
no ip mroute-cache
interface Vlan504
description WIMAX_UM4
ip address 10.10.54.16 255.255.255.0
ip pim sparse-mode
no ip mroute-cache
interface Vlan505
description WIMAX_UM5
ip address 10.10.55.16 255.255.255.0
ip pim sparse-mode
no ip mroute-cache
interface Vlan506
description WIMAX_UM6
ip address 10.10.56.16 255.255.255.0
ip pim sparse-mode
no ip mroute-cache
interface Vlan507
description WIMAX_UM7
ip address 10.10.57.16 255.255.255.0
ip pim sparse-mode
no ip mroute-cache
interface Vlan508
description WIMAX_UM8
ip address 10.10.58.16 255.255.255.0
ip pim sparse-mode
no ip mroute-cache
router eigrp 1
redistribute static
network 10.10.51.0 0.0.0.255
network 10.10.52.0 0.0.0.255
network 10.10.53.0 0.0.0.255
network 10.10.54.0 0.0.0.255
network 10.10.55.0 0.0.0.255
network 10.10.56.0 0.0.0.255
network 10.10.57.0 0.0.0.255
network 10.10.58.0 0.0.0.255
network 192.168.130.0
no auto-summary
ip classless
ip route 192.168.2.0 255.255.255.0 192.168.220.1
ip route 192.168.120.0 255.255.255.0 10.10.10.114
ip route 192.168.121.0 255.255.255.0 10.10.10.114
ip route 192.168.125.0 255.255.255.0 10.10.10.115
ip route 192.168.126.0 255.255.255.0 10.10.10.115
ip route 192.168.220.0 255.255.255.0 10.10.10.114
ip route 192.168.225.0 255.255.255.0 10.10.10.115
ip http server
Thanks a lot, Jon.... it's very important to me your help.
Bruno
No problem with the language, i envy anyone who can speak multiple languages and your english is fine.
Can you -
1) tell me which port on the 3560G connects back to the 3750 ?
2) when you say -
do you simply mean send packets to an from ?  If so you are running EIGRP so you would connect your router as such -
3560
int gi0/10 <--- this is an unused port
no switchport
ip address 192.168.5.1 255.255.255.252   <-- note you need to use an un used subnet
router eigrp 1
network 192.168.5.0 0.0.0.3
1841
int gi0/0
ip address 192.168.5.2 255.255.255.252
router eigrp 1
the above would establish an EIGRP peering between the 3560 and the 1841 and then they would exchange routes and you should be able to connect from the 3750 *** note i say should but can you confirm the question asked in 1) above.
Jon
Thanks Jon!
The port of the 3560G wich connects back to the central router 3750 it's g0/24 (Vlan2XX).
Well, my 1841 (wich is connect to 3560G by wimax on port f0/5, bridging mode) config is:
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.500
ip address 10.10.50.53 255.255.255.0
interface FastEthernet0/0.503
encapsulation dot1Q 503
ip address 10.10.53.1 255.255.255.0
ip pim sparse-mode
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.513
encapsulation dot1Q 513
ip address 192.168.146.1 255.255.255.0
ip pim sparse-mode
interface Cellular0/0/0
no ip address
encapsulation ppp
shutdown
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 192.168.146.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
My question is, i have 20 3560G Layer 3 switches..... in wich any 1841 can connect. One time, one 1841 can connect to one 3560 but in other time it can connect to another 3560....
It's a tricky question... and i don´t now how to solve it.
Bruno
I'm finding it difficult to understand your config. On the 3560 you have gi0/24 which is a trunk connecting back to the 3750. But on the 3750 you have subinterfaces on port channel 1 for what looks like all your 3560 connections. But this wouldn't work because you need a trunk to each switch ?
And if you are routing vlans on each 3560 why have you used trunk links.
From the above config gi0/24 on the 3560 connects back to the 3750. What port on the 3750 is used for that connection ?
Re the 1841 - is the problem that it is not receiving routes ?
Jon
Jon,
Yes, on the 3750 i have subinterfaces on port channel 1 for all my 3560 connections. On 3750 router i have just to ports to connect to all my 20 3560 Layer 3 switches, i put all 20 vlan on port-channel and configured port-channel on g0/0 and g0/1.
I used trunk links on my 3560 because they are connected (g0/24) to backbone by alcatel equipment to 3750 router.
The problem is, because i can have all my 8 1841 routers attached on any 20 3560G i cannot routing to central 3750 router.
Okay, that makes a bit more sense now.
So when you connect an 1841 router, do you see any routes coming through. Did you try debugging EIGRP.
When you connect an 1841 to a 3560 they must share a common subnet for the EIGRP adjacency to work. So from your 1841 config which 3560 switch did you connect it to and how were the two ends configured ?
Jon
Jon,
First of all sorry but i made a mistake about central router model, it´s one 7301 router and not a 3750 switch...
Yes, i've seen some routes coming through.
I can connect any of mine eigth 1841 routers to any of mine 3560G switches...... it can´t be static... one time one router 1841 connect to one 3560G and other time, same router 1841 can connect to another 3560G.
Router 1841 it's a mobile unit that can connect to any fixed station (3560G switch).
Bruno
Bruno
So you see routes coming through but are still not able to connect ?
Or is it that you can connect but when you move it to another 3560 then you can't connect without reconfiguring the device ?
I'm not sure exactly what the issue is ?
Jon
Yes! I see routes coming through but i'm not be able to connect from central 7301 router to 1841 mobile router, because central route 7301 have this routing table:
D       10.10.51.0/24 [90/3072] via 10.10.50.39, 00:03:38, Port-channel1.500
                      [90/3072] via 10.10.10.153, 00:03:38, Port-channel1.220
                      [90/3072] via 10.10.10.145, 00:03:38, Port-channel1.219
                      [90/3072] via 10.10.10.137, 00:03:38, Port-channel1.218
                      [90/3072] via 10.10.10.129, 00:03:38, Port-channel1.217
                      [90/3072] via 10.10.10.113, 00:03:38, Port-channel1.215
                      [90/3072] via 10.10.10.105, 00:03:38, Port-channel1.214
                      [90/3072] via 10.10.10.81, 00:03:38, Port-channel1.211
                      [90/3072] via 10.10.10.49, 00:03:38, Port-channel1.207
                      [90/3072] via 10.10.10.73, 00:03:38, Port-channel1.210
                      [90/3072] via 10.10.10.33, 00:03:38, Port-channel1.205
                      [90/3072] via 10.10.10.25, 00:03:40, Port-channel1.204
                      [90/3072] via 10.10.10.9, 00:03:40, Port-channel1.202
                      [90/3072] via 10.10.10.1, 00:03:40, Port-channel1.201
D       10.10.52.0/24 [90/3072] via 10.10.50.39, 00:03:40, Port-channel1.500
                      [90/3072] via 10.10.10.153, 00:03:40, Port-channel1.220
                      [90/3072] via 10.10.10.145, 00:03:40, Port-channel1.219
                      [90/3072] via 10.10.10.137, 00:03:40, Port-channel1.218
                      [90/3072] via 10.10.10.129, 00:03:40, Port-channel1.217
                      [90/3072] via 10.10.10.113, 00:03:40, Port-channel1.215
                      [90/3072] via 10.10.10.105, 00:03:40, Port-channel1.214
                      [90/3072] via 10.10.10.81, 00:03:40, Port-channel1.211
                      [90/3072] via 10.10.10.49, 00:03:40, Port-channel1.207
                      [90/3072] via 10.10.10.41, 00:03:40, Port-channel1.206
                      [90/3072] via 10.10.10.33, 00:03:40, Port-channel1.205
D       10.10.53.0/24 [90/3072] via 10.10.50.39, 00:03:40, Port-channel1.500
D       10.10.54.0/24 [90/3072] via 10.10.50.39, 00:03:40, Port-channel1.500
D       10.10.55.0/24 [90/3072] via 10.10.50.39, 00:03:40, Port-channel1.500
D       10.10.56.0/24 [90/3072] via 10.10.50.39, 00:03:40, Port-channel1.500
                      [90/3072] via 10.10.10.1, 00:03:46, Port-channel1.201
D       10.10.57.0/24 [90/3072] via 10.10.50.39, 00:03:46, Port-channel1.500
                      [90/3072] via 10.10.10.153, 00:03:46, Port-channel1.220
                      [90/3072] via 10.10.10.145, 00:03:46, Port-channel1.219
                      [90/3072] via 10.10.10.137, 00:03:46, Port-channel1.218
                      [90/3072] via 10.10.10.129, 00:03:46, Port-channel1.217
                      [90/3072] via 10.10.10.113, 00:03:46, Port-channel1.215
                      [90/3072] via 10.10.10.105, 00:03:46, Port-channel1.214
                      [90/3072] via 10.10.10.81, 00:03:46, Port-channel1.211
                      [90/3072] via 10.10.10.49, 00:03:46, Port-channel1.207
                      [90/3072] via 10.10.10.41, 00:03:46, Port-channel1.206
                      [90/3072] via 10.10.10.33, 00:03:46, Port-channel1.205
                      [90/3072] via 10.10.10.25, 00:03:46, Port-channel1.204
                      [90/3072] via 10.10.10.9, 00:03:46, Port-channel1.202
D       10.10.58.0/24 [90/3072] via 10.10.50.39, 00:03:46, Port-channel1.500
Can i mail you a schematic drawing?
Bruno
You can send me  private message ie. click on your username and you will see you can send a private message.
But when you connect up the 1841 to a 3560 if the 1841 advertises it's routes to the 3560 then the 3560 should send them to the 7301. There is no reason why the 7301 should not be able to connect to the 1841 if all the routing was working ie. it should see the 1841 routes via the port channel connection to the 3560.
Jon
The problem is,
each 3650 have one vlan for each 1841 (vlan 501-508).
For example:
interface Vlan506
And in eigrp it announciates this network to 7301:
router eigrp 1
redistribute static
no auto-summary
In 7301 it receives multiples routes to same destiny:
But 7301 can´t decide because all routes have same metric and AD. Am i wrong?
