cisco Nexus9000 does not work properly
Loc Nguyen
Nexus9000 SW---------Trunk---------------Cisco Layer2 SW
+ 10.0.1.251 is the interface ip on the Nexus-SW
+ 10.0.2.254 is the interface ip of the Layer2-SW
+ 10.0.2.26 is a device connect to the Layer2-SW
- We have an issue that vlan 10.0.1.251 can not ping 10.0.2.26:
core-1# ping 10.0.2.26 source 10.0.1.251
PING 10.0.2.26 (10.0.2.26) from 10.0.1.251: 56 data bytes
Request 0 timed out
Request 1 timed out
- But it can ping 10.0.2.254:
core-1# ping 10.0.2.254 source 10.0.1.251
PING 10.0.2.254 (10.0.2.254) from 10.0.1.251: 56 data bytes
Request 0 timed out
64 bytes from 10.0.2.254: icmp_seq=1 ttl=253 time=1.077 ms
64 bytes from 10.0.2.254: icmp_seq=2 ttl=253 time=0.823 ms
- 10.0.2.26 has the correct default-gateway because I can ping it from other subnets:
core-1# ping 10.0.2.26 source 10.5.5.251
PING 10.0.2.26 (10.0.2.26) from 10.5.5.251: 56 data bytes
Request 0 timed out
64 bytes from 10.0.2.26: icmp_seq=1 ttl=62 time=1.096 ms
64 bytes from 10.0.2.26: icmp_seq=2 ttl=62 time=0.684 ms
It is a weird issue to me. I think the issue stays on the cisco Nexus9000.
Could you advise?
Loc
balaji.bandi
we need more information in terms of config and is the Nexys 9K in vPC ? ( do you have any dual-path nexus that can reach this IP address ?)
post the configuration which was connected to Layer 2 switch
show run interfaces ethernet x/x - on nexus side and Layer2 switch side.
show ip interface brief
show span summary
Do you see any abnormal logs on the Layer 2 switch and nexus switch?
BB
this is orphan port that the SW connect to?
