EFFECTS OF CONFIGURING SYSTEM JUMBO FRAME
Hi, we have a 6506 switch which had a default setting of mtu 1500.
Now we have a client who is requesting that we set the jumbo frame to 9216.
I configured      # int fx/x
                      # mtu 9216
This did not solve the problem as they said they are still not able to get the desired mtu value.
Am thinking of configuring a ssytem jumbomtu 9216 on the switch
What are the implication?
Would there be any performance issue after initiating this command?
Would it solve the current issue?
Kenny
JohnTylerPearce
Level 7
Level 7
If you issue that global configuration command, it is very possible to run into problems. That command will set the mtu to the max of 9216 for all ports, so if you have a port going to your WAN provider, etc, it will cause frames to be fragmented on their end, since most likely the other port will be 1500. So take 9216/1500, and could have lots of issues with CPU performance. I've had friends that have had that happen to them.
I haven't set the MTU value on a 6500, but I have done it on a 3750/2960-s, and I had to reboot the switch. If you run the command 'show system mtu', it will say something like "won't take place until next reboot'.
Is there a specific reason, the client needs to have this value set on the port? I would think going to the interface, and putting in the mtu command would work. Did you verify that the MTU value took on the interface?
pille1234
Level 3
Level 3
Be aware that all interfaces between source and destination interface need to be configured for jumbo frames. That includes the layer-3 Vlan-interfaces as well.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
                      # mtu 9216
You normally need to insure jumbo is enabled end-to-end.
Hmm, is that supported on the 6500?  On 6500s, MTU can be set per interface.  Not all line cards support jumbo.  If a system wide jumbo setting is supported, it might enable jumbo for all interfaces that can support it.  Biggest implication is an interface might transmit a jumbo to a device incapable of receiving it.
To the 6500?  Shouldn't be.  Existing hosts?  May enhance or decrease their performance, or break transfers.
Not enough information to say.
Thanks so much for the information. After issuing
S(conf)# int g3/23
               mtu 9216
I also did
S(conf)# system jumbomtu 9216          (didnt ask for a system restart and not much difference as Joseph pointed out)
I issued the show vlan mtu
6506#     sh vlan mtu
VLAN    SVI_MTU    MinMTU(port)   MaxMTU(port)  MTU_Mismatch
113       1500          1500                      1500           No
114       1500          1500                      1500           No
115        1500          9216                     9216           No
116       1500          9216                      9216           No
6506#     sh int mtu
Port       Name               MTU
Gi3/23     V_TRUNK      9216
The design scenario we have is V switch connects to our 6506. Our 6506 connects to a fiber equipment (Optical Line Terminal). The OLT connects to an ONU which is deployed to the Client.
The Client mentioned they oberved a considerable improvement but they still cant get to the desired mtu of 9216
Kehinde
