EFM
what is Ethernet of the First mile ?
Ganesh Hariharan
Hi ,
Ethernet of the first mile is actually a combination of ethernet standard 802.3ah which is amendment of media access control parameters, physical layers and certain management parameters for access network and the first mile refer to communication n/w links the customer premises.
For more detailed explanation you can check the below
EFM
Hope it Helps..
-GI
Rate if it Helps
Is this protocol support on NCS5002 release 6.3.2? I checked website and did not find any information or configuration guide for that.
