EFM
there is any EFM module for ISR4000 ?
Julio E. Moisa
Based on these links it is not supported on this router model:
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/GSHDSL_EFM_ATM_HWICS.html
Prerequisites for Cisco G.SHDSL EFM/ATM EHWICs
Ensure that you have the appropriate Cisco router to serve as the host router.
The following Cisco  routers support Cisco G.SHDSL EFM/ATM EHWICs:
Cisco 1921 ISR
Cisco 1941 ISR
Cisco 2901 ISR
Cisco 2911 ISR
Cisco 2921 ISR
Cisco 2951 ISR
Cisco 3925 ISR
Cisco 3925-E ISR
Cisco 3945 ISR
Cisco 3945-E ISR
Use the show version command to ensure that the router is running the correct IOS software. The C888EA and EHWIC-4SHDSL-EA models require Cisco IOS Release Release: <optional, example: Cisco IOS Release 15.1(1)T> or later.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
