03-19-2014 10:58 AM - edited 03-07-2019 06:46 PM
I need help on this. I have two Cisco Catalyst 6807 with quad sup 2T. I'm trying to upgrade to latest IOS with the following procedure :
I'm upgrading from IOS 151-2.SY1 to 151-2.SY2.
So I'm doing this :
# issu loadversion bootdisk:s2t54-adventerprisek9-mz.SPA.151-2.SY2.bin
At this point, the standby-ICS sup reboot fine with the new IOS.
Then the standby sup reboots and after several minutes I always get this :
* %ISSU_PROCESS-SW1-3-ABORT: Starting abort sequence, reason: LOADVERSION: New Standby has failed to respond
At this point, the process fail and do a rollback.
So my question is, does eFSU supports quad-sup ?
11-15-2015 04:27 PM
Exactly same problem for me, is there any one can help on this?
thanks
Marco
03-04-2022 01:31 AM
Exactly the same message for me, does anyone got any answers ?
The IOS image has been copied to the bootdisk: directory of the 4 SUP, can it be a problem for the eFSU process ?
SRS
