08-19-2021 05:14 AM
Cisco Catalyst 9300 is using as core switch, I am facing issue in Eigrp Protocol. I have configured AD value by using Distance using "distance eigrp 70 70", but as I am checking the routes it is showing 252 AD Value.
Please find the logs and help in this case/
Solved! Go to Solution.
08-19-2021 05:22 AM
Can you post the big of config EIGRP and post the output -
#show ip route eigrp
08-20-2021 07:59 AM
Hello @himanshudwivedi ,
your device is running two EIGRP processes 1 and 10
can you post
show ip eigrp 1 neighbors
and
show ip eigrp 10 neighbors
Hope to help
Giuseppe
08-19-2021 05:22 AM
08-19-2021 05:32 AM
08-19-2021 06:04 AM
post
show run | begin router eigrp
or show run section router eigrp
In addition to what has been noted by Georg that is the AD of D EX should be higher then the AD of internal routes I'm afraid there can be some command that rise the AD to 252 for all routes coming from neighbor 10.1.111.4
D EX 10.2.0.0/24 [252/257] via 10.1.111.4, 00:10:19, Vlan111
D EX 10.2.1.0/24 [252/257] via 10.1.111.4, 00:10:19, Vlan111
D EX 10.2.2.0/23 [252/257] via 10.1.111.4, 00:10:19, Vlan111
Final note: playing with AD values should be a last resort tool to be used only when really needed, for example if you have multiple EIGRP processes you may need to tune the AD on the "core" instance and on the "edge" instance(s) in any case the AD for external routes should be greater then that of internal routes for protocol stability.
Edit: I think you have multiple EIGRP processes running on this device so you need to look on all of them the routes we see can come on another process.
You should be able to add the process AS number at the end of show ip route eigrp
Hope to help
Giuseppe
08-19-2021 08:39 AM - edited 08-19-2021 08:46 AM
08-19-2021 06:18 AM
You have not posted :
Can you post the bit of config EIGRP
08-19-2021 08:45 AM
08-19-2021 05:29 AM
the first value changes the internal (D routes) AD, the second one the external (D EX routes) AD. I am not sure that both can be the same.
Can you for the sake of testing use:
distance eigrp 70 71
and check if that value is reflected in the output of 'show ip route' ?
08-19-2021 02:26 PM - edited 08-20-2021 02:28 PM
you can have same values of internal and external EIGRP routes; show ip protocols
Distance: internal 70 external 70
Regards, ML
**Please Rate All Helpful Responses **
08-19-2021 07:27 PM
I tried changing the Values but no luck.... Interesting this is that after removing that distance commands then to it is taking AD value of 252/257...
08-20-2021 07:59 AM
can you post
and
Hope to help
Giuseppe
08-20-2021 10:16 PM
Its a Bug in Cisco 9K series Switch with Version 16.12.4 and the bug code is CSCvw38433
08-21-2021 02:19 PM
