eigrp and ospf on NBMA
carl_townshend
Hi all
when using protocols such as eigrp and ospf on frame relay environments etc, do you have to use the neighbour command?, and do I just need to add all the neighbours that should be reached uder the router ospf command ? is this also the same for eigrp ? OR when using the broadcast command, d i not need to put the neighbours in as the multicast will be replicated to all circuits ?
