EIGRP Best Path
Mokhalil82
Level 4
Level 4
Hi Guys
I have 2 routed links between two sites a 10G on 10G bearer and 5G on 10G bearer. Will be configuring EIGRP either side. How can I get the traffic to primarily use the 10G link.
May be a simple question for someone. Any help will be much appreciated. Someone mentioned something about using a bandwidth command.
Reza Sharifi
The bandwidth command should do it.  Here is doc with config example:
R2# configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)# interface ethernet0
R2(config-if)# bandwidth 5000
R2(config-if)# end
http://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/13673-14.html
Reza Sharifi
R2(config-if)# end
Thanks Reza I thought it was as simple as that, just making sure
