Eigrp command missing on switch 3850
r.randriamanana
Hi all,
Please help,
router(config)#router ?
ospf
rip
eigrp is missing
Thanks in advanced
Yes lanbase license does not support eigrp , you will need at least ipbase and that will only give you stub eigrp , you will need ipservices license for full eigrp in cli
so unfortunately if you want to use that feature you will need to buy a license for routing
6 Replies 6
Mark Malone
You dont have the right license then , what is your current license ?
sh license right-to-use
Slot# License name Type Count Period left
1 lanbase permanent N/A Lifetime
License Level on Reboot: lanbase
2 lanbase permanent N/A Lifetime
Hello Mark,
is there any portal web to buy a licenses in the cisco website?
Excellent
