eigrp doesn't have routing update and sia issue
Aaron EOM
SWRNDHQ4506_1#sh ip eigrp neighbors
IP-EIGRP neighbors for process 913
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq Type
                                            (sec)         (ms)       Cnt Num
0   10.130.34.3             Vl11              12 14:17:26   25   200  0  0
1   10.142.60.17            Gi6/24            11 14:20:28    9   200  0  455380080
2   10.142.36.10            Po2               13 2w0d        1   200  0  421786374
Jul 26 07:42:44: %DUAL-3-SIA: Route 10.129.153.0/24 stuck-in-active state in IP-EIGRP(0) 913.  Cleaning up
hi
SWRNDHQ4506_1 switch has not eigrp rouing update. and occuerd SIA issue.
that switchs are just linked fiber cable in same location RACK.
but one switch can not updates the Eigrp routing route.
i have changed cable and etherchannel port and gbic. but i didn't see any routing updates in SWRNDHQ4506_1 switch.
and i can't find the BUG of that issue and any information.
let me know who has see that's issue and know how can do troubleshoot to that issue.
5 Replies 5
answanso
Can you please provide the following information:
- EIGRP routing process configuration on both sides
- Port-Channel configuration on both sides
- Physical interfaces bound to the port-channel configuration on both sides
- ping 224.0.0.10 source from the port-channel interface on both sides
- show etherchannel summary (show port-channel sum on Nexus)
Anthony
moncy_cisco
Hi Su deok eom,
Let me understand the topology first,
You have core 1 core 2 eigrp neighbors , and edge switch.
Edge switch is the neighbor of the cores and it's advertising the prefix 10.129.153.0/24
Can you please tell me the interface of Core's connected to the edge.
Also so required information shown below
Neighbor table on core 2, topology table and routing table of core 1 and 2, neighbor table,topology table routing table and eigrp show run config on edge switch who is advertising 10.129.153.0/24.
Moncy.
hi answanso and thomas.
thanks for your reply.
this is our all diagram.
BRANCH_1's left side 4506 has not routing update from right side 4506 switch.
i have tested connect to make routed port on reft 4506 and right 4506
but it has same . doesn't updated routing on left 4506 from right 4506
is this hardware fault or software BUG ?
i attached two switch's configuration
SWRNDHQ4506_1 is BRANCH_1's left switch .
SWRNDHQ4506_2 is BRANCH_21s rigrt switch
----------------------------SWRNDHQ4506_1-----------------------------------
Building configuration...
Current configuration : 25022 bytes
! Last configuration change at 22:11:49 KST Wed Jul 25 2012 by cityhyun
! NVRAM config last updated at 22:11:54 KST Wed Jul 25 2012 by cityhyun
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service compress-config
hostname SWRNDHQ4506_1
boot-start-marker
boot system bootflash:cat4500-entservicesk9-mz.122-37.SG.bin
boot-end-marker
logging buffered 16000 debugging
enable secret 5
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication enable default group tacacs+ enable
aaa accounting connection default start-stop group tacacs+
aaa session-id common
clock timezone KST 9
qos
qos dbl
qos map dscp 24 25 26 27 28 29 30 31 to tx-queue 4
qos map dscp 32 33 34 35 36 37 38 39 to tx-queue 4
qos map cos 3 to dscp 26
qos map cos 5 to dscp 46
ip subnet-zero
no ip source-route
no ip domain-lookup
ip domain-name amorepacific.com
ip dhcp relay information trust-all
ip dhcp snooping
no ip bootp server
ip ssh version 2
vtp domain SWR&D
vtp mode transparent
power redundancy-mode redundant
no file verify auto
spanning-tree mode pvst
spanning-tree vlan 11,45,69,72,74,81-86,166-235 priority 24576
vlan internal allocation policy ascending
vlan 11,15-16,45,66-76
vlan 128
name Wireless-APGUEST
vlan 166-176,235
vlan 247
name Cloud-Test
vlan 248
name Wireless
policy-map autoqos-voip-policy
  class class-default
    dbl
interface Port-channel1
switchport
switchport mode trunk
interface Port-channel2
description SW2RNDHQ4506_1 Gig 3/47 - Gig 3/48
ip address 10.142.36.9 255.255.255.252
interface Port-channel12
switchport
interface Port-channel13
description SW-RND-HQ-5508-02 - 10.130.34.12(192.168.100.202)
switchport
interface GigabitEthernet1/1
logging event link-status
interface GigabitEthernet1/2
interface GigabitEthernet3/1
description SWR&DHQ4506_2 Gig 0/1
channel-group 1 mode on
interface GigabitEthernet3/2
description SWR&DHQ4506_2 Gig 0/2
interface GigabitEthernet3/3
description SWR&D113560_1 Gi0/1 - 10.130.68.4
interface GigabitEthernet3/4
switchport access vlan 11
switchport mode access
interface GigabitEthernet3/5
description SWR&D313560_1 Gi0/1 - 10.130.70.4
interface GigabitEthernet3/6
switchport access vlan 12
interface GigabitEthernet3/7
description SWR&D223560_1 Gi0/1 - 10.130.72.4
interface GigabitEthernet3/8
interface GigabitEthernet3/9
description SWR&DHE3560_1 Gi0/1 - 10.130.66.4
interface GigabitEthernet3/10
switchport access vlan 14
interface GigabitEthernet3/11
description SWR&DHE3560_3 Gi0/1 - 10.130.67.4
interface GigabitEthernet3/12
interface GigabitEthernet3/13
channel-group 13 mode on
interface GigabitEthernet3/14
interface GigabitEthernet3/15
description SW2RNDHQ4506_1 Gi3/47 - 10.142.36.10
no switchport
no ip address
channel-group 2 mode on
interface GigabitEthernet3/16
description SW2RNDHQ4506_1 Gi3/48 - 10.142.36.10
no switchport
no ip address
interface GigabitEthernet3/17
description SWMANHQ3560_1 Gi0/1 - 10.130.35.6
ip access-group Deny_Multicast in
qos trust cos
auto qos voip trust
tx-queue 3
   bandwidth percent 33
   priority high
   shape percent 33
service-policy output autoqos-voip-policy
interface GigabitEthernet3/18
description SWRNDHQ5508 - 10.130.34.10(192.168.100.203)
interface GigabitEthernet6/1
description SWR&DHQ1841 Fas 0/1
no switchport
ip address 10.130.209.1 255.255.255.0
power inline never
interface GigabitEthernet6/2
switchport access vlan 74
power inline never
interface GigabitEthernet6/3
description HUB_3Sector_1F_1
power inline never
interface GigabitEthernet6/4
description SWR&D133560_1
power inline never
qos trust cos
auto qos voip trust
tx-queue 3
   priority high
   shape percent 33
interface GigabitEthernet6/5
description SWR&D133560_2
power inline never
qos trust cos
auto qos voip trust
tx-queue 3
   priority high
   shape percent 33
interface GigabitEthernet6/6
power inline never
qos trust cos
auto qos voip trust
tx-queue 3
   priority high
   shape percent 33
interface GigabitEthernet6/7
switchport trunk native vlan 74
no logging event link-status
power inline never
spanning-tree portfast
interface GigabitEthernet6/8
description SWRnDHQ2851
no switchport
ip address 10.130.227.1 255.255.255.0
power inline never
speed 1000
duplex full
interface GigabitEthernet6/9
description SWR&D233560
power inline never
qos trust cos
auto qos voip trust
tx-queue 3
   priority high
   shape percent 33
interface GigabitEthernet6/10
description ## SW2RnDHQ2851 FA0/0 ##
no switchport
ip address 10.130.229.1 255.255.255.252
power inline never
speed 1000
duplex full
interface GigabitEthernet6/11
switchport access vlan 75
power inline never
interface GigabitEthernet6/12
switchport access vlan 70
power inline never
interface GigabitEthernet6/13
description SWR&D333560
power inline never
qos trust cos
auto qos voip trust
tx-queue 3
   priority high
   shape percent 33
interface GigabitEthernet6/14
switchport access vlan 76
power inline never
interface GigabitEthernet6/15
description SWRnDHQ224_1
no switchport
ip address 10.130.237.1 255.255.255.0
power inline never
speed 100
duplex full
interface GigabitEthernet6/16
description SWRnDHQ224_2
no switchport
ip address 10.130.239.1 255.255.255.0
power inline never
speed 100
duplex full
interface GigabitEthernet6/17
description SWRnDHQ224_3
no switchport
ip address 10.130.241.1 255.255.255.0
power inline never
speed 100
duplex full
interface GigabitEthernet6/18
description SWRnDHQ224_4
no switchport
ip address 10.130.243.1 255.255.255.0
power inline never
speed 100
duplex full
interface GigabitEthernet6/19
description SWRnDHQ224_5
no switchport
ip address 10.130.245.1 255.255.255.0
power inline never
speed 100
duplex full
interface GigabitEthernet6/20
description Cloud_PC_01
interface GigabitEthernet6/21
description Cloud_PC_02
power inline never
interface GigabitEthernet6/22
description To Domain_SVR1
power inline never
interface GigabitEthernet6/23
description SWR&DHQ1400 MAN
power inline never
interface GigabitEthernet6/24
description ### to SEBISMD6513_1 - 10.142.50.229 ###
no switchport
ip address 10.142.60.18 255.255.255.248
speed 100
duplex full
qos trust dscp
auto qos voip trust
flowcontrol receive on
tx-queue 3
   priority high
   shape percent 33
interface Vlan1
no ip address
shutdown
interface Vlan10
no ip address
shutdown
interface Vlan11
ip address 10.130.34.2 255.255.255.0
ip access-group 101 in
ip access-group 101 out
ip helper-address 10.129.10.33
no ip redirects
standby 10 ip 10.130.34.1
standby 10 priority 110
standby 10 preempt
interface Vlan15
ip address 10.130.35.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.35.1
standby 10 priority 105
standby 10 preempt
interface Vlan16
ip address 10.130.40.2 255.255.255.0
no ip redirects
standby 40 ip 10.130.40.1
standby 40 priority 105
standby 40 preempt
interface Vlan45
ip address 10.130.45.2 255.255.255.0
ip access-group Block_CUCM_Port_45.4 out
standby 45 ip 10.130.45.1
standby 45 priority 110
standby 45 preempt
interface Vlan66
ip address 10.130.66.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.66.1
standby 10 preempt
interface Vlan67
ip address 10.130.67.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.67.1
standby 10 preempt
interface Vlan68
ip address 10.130.68.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.68.1
standby 10 preempt
interface Vlan69
ip address 10.130.69.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.69.1
standby 10 preempt
interface Vlan70
ip address 10.130.70.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.70.1
standby 10 preempt
interface Vlan71
ip address 10.130.71.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.71.1
standby 10 preempt
interface Vlan72
ip address 10.130.72.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.72.1
standby 10 preempt
interface Vlan73
ip address 10.130.73.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.73.1
standby 10 preempt
interface Vlan74
ip address 10.130.74.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.74.1
standby 10 preempt
interface Vlan75
ip address 10.130.75.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.75.1
standby 10 preempt
interface Vlan76
ip address 10.130.76.2 255.255.255.0
no ip redirects
standby 10 ip 10.130.76.1
standby 10 preempt
interface Vlan128
ip address 10.130.128.3 255.255.252.0
no ip redirects
standby 128 ip 10.130.128.1
standby 128 priority 105
standby 128 preempt
interface Vlan166
ip address 10.30.66.2 255.255.255.0
ip helper-address 10.130.0.3
standby 166 ip 10.30.66.1
standby 166 priority 110
standby 166 preempt
interface Vlan167
ip address 10.30.67.2 255.255.255.0
standby 167 ip 10.30.67.1
standby 167 priority 110
standby 167 preempt
interface Vlan168
ip address 10.30.68.2 255.255.255.0
standby 168 ip 10.30.68.1
standby 168 priority 110
standby 168 preempt
interface Vlan169
ip address 10.30.69.2 255.255.255.0
standby 169 ip 10.30.69.1
standby 169 priority 110
standby 169 preempt
interface Vlan170
ip address 10.30.70.2 255.255.255.0
standby 170 ip 10.30.70.1
standby 170 priority 110
standby 170 preempt
interface Vlan171
ip address 10.30.71.2 255.255.255.0
standby 171 ip 10.30.71.1
standby 171 priority 110
standby 171 preempt
interface Vlan172
ip address 10.30.72.2 255.255.255.0
standby 172 ip 10.30.72.1
standby 172 priority 110
standby 172 preempt
interface Vlan173
ip address 10.30.73.2 255.255.255.0
standby 173 ip 10.30.73.1
standby 173 priority 110
standby 173 preempt
interface Vlan174
ip address 10.30.74.2 255.255.255.0
standby 174 ip 10.30.74.1
standby 174 priority 110
standby 174 preempt
interface Vlan175
ip address 10.30.75.2 255.255.255.0
standby 175 ip 10.30.75.1
standby 175 priority 110
standby 175 preempt
interface Vlan176
ip address 10.30.76.2 255.255.255.0
standby 176 ip 10.30.76.1
standby 176 priority 110
standby 176 preempt
interface Vlan235
ip address 10.30.35.2 255.255.255.0
standby 235 ip 10.30.35.1
standby 235 priority 110
standby 235 preempt
interface Vlan247
ip address 10.130.247.3 255.255.255.0
no ip redirects
shutdown
standby 247 ip 10.130.247.1
standby 247 priority 105
standby 247 preempt
interface Vlan248
ip address 10.130.248.3 255.255.248.0
no ip redirects
standby 248 ip 10.130.248.1
standby 248 priority 105
standby 248 preempt
router eigrp 913
redistribute connected
redistribute static
network 10.130.34.2 0.0.0.0
network 10.142.36.9 0.0.0.0
network 10.142.60.18 0.0.0.0
no auto-summary
ip route 10.130.0.3 255.255.255.255 10.130.227.2
ip route 10.130.0.8 255.255.255.255 10.130.237.2
ip route 10.130.0.9 255.255.255.255 10.130.239.2
ip route 10.130.0.10 255.255.255.255 10.130.241.2
ip route 10.130.0.11 255.255.255.255 10.130.243.2
ip route 10.130.0.19 255.255.255.255 10.130.245.2
ip route 10.130.0.21 255.255.255.255 10.130.229.2
ip route 10.130.0.22 255.255.255.255 10.142.36.10
ip route 10.130.0.23 255.255.255.255 10.142.36.10
ip route 10.145.0.0 255.255.0.0 10.130.70.3
no ip http server
no ip http secure-server
ip tacacs source-interface Vlan11
ip access-list standard ADMIN_ACL
permit 10.129.221.80
permit 172.26.64.254
permit 10.129.221.70
permit 10.132.111.254
permit 172.26.105.254
permit 10.129.75.229
permit 10.129.75.230
permit 10.129.75.231
permit 10.130.81.254
permit 10.129.75.232
permit 10.129.75.233
permit 10.129.75.234
permit 10.129.75.235
permit 10.129.75.236
permit 10.129.75.237
permit 10.129.75.238
permit 10.129.75.239
permit 10.129.75.240
permit 10.129.66.245
permit 10.130.74.254
permit 10.129.66.244
permit 10.130.248.51
permit 172.26.2.254
permit 10.136.16.222
permit 10.136.16.221
permit 10.135.35.254
permit 10.132.33.254
permit 10.129.243.42
permit 10.135.33.254
permit 10.132.33.253
permit 172.26.27.254
permit 10.132.33.252
permit 10.131.35.254
permit 10.130.35.254
permit 10.131.33.254
permit 10.130.33.254
permit 10.135.36.254
permit 10.139.36.254
permit 10.133.242.31
permit 10.152.6.240
permit 10.133.240.22
permit 10.133.240.21
permit 10.152.6.229
permit 172.26.58.254
permit 10.152.6.230
permit 10.152.6.231
permit 10.152.6.236
permit 10.152.6.237
permit 10.152.6.238
permit 10.152.6.239
permit 10.152.6.232
permit 10.152.6.233
permit 10.152.6.234
permit 10.152.6.235
permit 10.152.12.30
permit 172.19.54.15
permit 172.19.55.15
permit 10.133.36.32
permit 10.133.30.29
permit 10.133.35.32
permit 10.133.31.30
permit 10.133.33.32
permit 10.133.30.30
permit 10.133.31.31
permit 172.19.52.31
permit 10.129.10.23
permit 10.134.34.15
permit 10.134.33.15
permit 10.134.35.9
permit 10.129.50.19
permit 10.152.12.52
permit 10.129.50.18
permit 10.133.54.21
permit 10.152.12.50
permit 10.129.50.20
permit 10.133.55.21
permit 10.152.12.51
permit 10.133.52.21
permit 10.133.53.20
permit 10.133.32.31
permit 10.129.243.200
permit 10.133.32.30
permit 10.133.33.31
permit 10.129.243.201
permit 10.129.243.202
permit 10.133.37.30
permit 10.129.50.15
permit 10.152.12.40
permit 10.140.50.15
permit 10.130.39.20
permit 172.26.3.9
permit 172.26.103.9
permit 10.129.66.19
permit 10.129.67.18
permit 10.129.67.19
permit 10.129.66.18
permit 10.129.67.20
permit 10.136.128.222
permit 10.136.128.221
permit 10.134.112.15
permit 10.129.66.50
ip access-list standard SNMP_ACL
permit 10.129.30.176
permit 10.129.221.30
ip access-list extended Block_CUCM_Port_45.4
permit ip host 10.129.35.10 host 10.130.45.4
permit ip host 10.129.35.4 host 10.130.45.4
permit ip host 10.129.35.11 host 10.130.45.4
permit ip host 10.129.35.20 host 10.130.45.4
permit ip host 10.129.64.4 host 10.130.45.4
permit ip host 10.130.41.4 host 10.130.45.4
permit ip host 10.136.1.4 host 10.130.45.4
permit ip host 10.133.33.30 host 10.130.45.4
permit ip host 10.129.50.15 host 10.130.45.4
permit ip host 10.129.243.42 host 10.130.45.4
permit ip host 10.133.30.30 host 10.130.45.4
permit ip host 10.133.31.30 host 10.130.45.4
permit ip host 10.133.32.30 host 10.130.45.4
permit ip host 10.133.33.31 host 10.130.45.4
permit ip host 10.133.240.21 host 10.130.45.4
permit ip host 10.133.30.29 host 10.130.45.4
permit ip host 10.133.31.31 host 10.130.45.4
permit ip host 10.133.32.31 host 10.130.45.4
permit ip host 10.133.33.32 host 10.130.45.4
permit ip host 10.133.240.22 host 10.130.45.4
permit ip host 10.133.35.32 host 10.130.45.4
permit ip host 10.133.36.32 host 10.130.45.4
permit ip host 10.133.37.30 host 10.130.45.4
permit ip host 10.129.66.244 host 10.130.45.4
permit ip host 10.129.66.245 host 10.130.45.4
permit ip host 10.134.33.15 host 10.130.45.4
permit ip host 10.134.34.15 host 10.130.45.4
permit ip host 10.134.35.9 host 10.130.45.4
permit ip host 172.19.55.15 host 10.130.45.4
permit ip host 172.19.54.15 host 10.130.45.4
permit ip host 172.26.3.9 host 10.130.45.4
permit ip host 172.26.103.9 host 10.130.45.4
permit ip host 10.140.50.15 host 10.130.45.4
permit ip host 10.134.112.15 host 10.130.45.4
permit ip host 10.130.74.254 host 10.130.45.4
permit ip host 10.130.35.254 host 10.130.45.4
permit ip host 10.130.33.254 host 10.130.45.4
permit ip host 10.130.248.51 host 10.130.45.4
permit ip host 10.130.39.20 host 10.130.45.4
permit ip host 172.26.105.254 host 10.130.45.4
permit ip host 10.139.36.254 host 10.130.45.4
permit ip host 10.132.33.254 host 10.130.45.4
permit ip host 10.131.33.254 host 10.130.45.4
permit ip host 10.135.33.254 host 10.130.45.4
permit ip host 10.135.36.254 host 10.130.45.4
permit ip host 172.26.2.254 host 10.130.45.4
permit ip host 172.26.64.254 host 10.130.45.4
permit ip host 172.26.58.254 host 10.130.45.4
permit ip host 172.26.27.254 host 10.130.45.4
permit ip host 10.132.111.254 host 10.130.45.4
permit ip host 10.131.35.254 host 10.130.45.4
permit ip host 10.129.66.50 host 10.130.45.4
permit ip host 10.129.67.20 host 10.130.45.4
permit ip host 10.129.50.20 host 10.130.45.4
permit ip host 10.129.243.200 host 10.130.45.4
permit ip host 10.129.66.19 host 10.130.45.4
permit ip host 10.129.67.19 host 10.130.45.4
permit ip host 10.129.50.19 host 10.130.45.4
permit ip host 10.129.243.201 host 10.130.45.4
permit ip host 10.129.66.18 host 10.130.45.4
permit ip host 10.129.67.18 host 10.130.45.4
permit ip host 10.129.50.18 host 10.130.45.4
permit ip host 10.129.243.202 host 10.130.45.4
permit ip host 10.129.221.70 host 10.130.45.4
permit ip host 10.129.221.80 host 10.130.45.4
permit ip host 10.129.10.23 host 10.130.45.4
permit ip host 10.133.52.21 host 10.130.45.4
permit ip host 10.133.53.20 host 10.130.45.4
permit ip host 10.133.54.21 host 10.130.45.4
permit ip host 10.133.55.21 host 10.130.45.4
permit ip host 10.133.242.31 host 10.130.45.4
permit ip host 172.19.52.31 host 10.130.45.4
permit ip host 10.136.16.221 host 10.130.45.4
permit ip host 10.136.16.222 host 10.130.45.4
permit ip host 10.136.128.221 host 10.130.45.4
permit ip host 10.136.128.222 host 10.130.45.4
deny   tcp any host 10.130.45.4 eq www
deny   tcp any host 10.130.45.4 eq 8443
permit ip any any
logging trap notifications
logging facility local2
logging 10.129.10.23
access-list 101 deny   tcp any any eq 3410
access-list 101 deny   tcp any any eq 5554
access-list 101 deny   tcp any any eq 6129
access-list 101 permit ip any any
access-list 101 permit tcp any any
snmp-server community RO SNMP_ACL
snmp-server trap-source Vlan11
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps flash insertion removal
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps envmon fan shutdown supply temperature
snmp-server enable traps port-security
snmp-server enable traps bgp
snmp-server enable traps config-copy
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps isis
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps msdp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps rf
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
snmp-server host 10.129.30.176
tacacs-server host 10.129.30.155
tacacs-server directed-request
tacacs-server key 7
radius-server source-ports 1645-1646
control-plane
banner motd ^C
* IBMs internal systems must only be used for conducting IBMs business or *
* for purposes authorized by IBM management. Use is subject to audit at any *
* time by IBM management. *
* use of this system without authorization is prohibited.
^C
default-value exec-character-bits 8
line con 0
exec-timeout 5 0
password 7
logging synchronous
stopbits 1
line vty 0 4
access-class ADMIN_ACL in
exec-timeout 5 0
password 7
transport input telnet ssh
transport output telnet ssh
line vty 5 15
exec-timeout 5 0
password 7
ntp clock-period 17179514
ntp server 203.248.240.103
end
----------------------------SWRNDHQ4506_2-----------------------------------
Current configuration : 24488 bytes
! Last configuration change at 15:31:33 KST Thu Jul 26 2012 by nolsia
! NVRAM config last updated at 22:15:27 KST Wed Jul 25 2012 by cityhyun
version 12.2
no service pad
hostname SWRNDHQ4506_2
boot-start-marker
boot-end-marker
enable secret 5
aaa new-model
qos
qos dbl
ip subnet-zero
no ip source-route
no ip domain-lookup
ip dhcp snooping
no ip bootp server
ip ssh version 2
vtp domain SWR&D
no file verify auto
spanning-tree vlan 15-16,66-68,70-71,73,75-76,128 priority 24576
vlan 128
vlan 166-176,235
vlan 247
name Cloud-Test
vlan 248
name Wireless
  class class-default
    dbl
interface Tunnel0
bandwidth 100000
ip address 10.142.41.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
load-interval 30
delay 10
keepalive 10 3
tunnel source GigabitEthernet6/23
tunnel destination 10.142.40.33
switchport
description SW2RNDHQ4506_2 Gig 3/47 - Gig 3/48
ip address 10.142.36.13 255.255.255.252
switchport
description SWR&DHQ4506_1 Gig 3/1
description SWR&DHQ4506_1 Gig 3/2
description SWR&D213560 Gig 0/1
description SWR&D123560 Gig 0/1
description SWR&D323560 Gig 0/1
description SWR&DHE3560_2 Gig 0/1
description SWR&DHE3560_4 Gig 0/1
no switchport
no ip address
description SW2RNDHQ4506_2 Gig 3/48
no switchport
no ip address
channel-group 12 mode on
description SWR&DHQ1841 Fas 0/0
no switchport
ip address 10.130.206.1 255.255.255.0
description SWR&D131131_1 - 10.130.74.11
description SWR&D131131_2 - 10.130.74.12
description SWR&D131131_3 - 10.130.74.13
description Testing
description SWRDHQ7835CMS02 - 10.130.45.4
switchport access vlan 45
no switchport
ip address 10.130.228.1 255.255.255.0
speed 1000
duplex full
description ## SW2RnDHQ2851 FA0/1 ##
no switchport
ip address 10.130.230.1 255.255.255.252
power inline never
speed 1000
duplex full
description Cloud_PC_03
description Cloud_PC_04
description Cloud_PC_05
no switchport
ip address 10.130.238.1 255.255.255.0
speed 100
duplex full
no switchport
ip address 10.130.240.1 255.255.255.0
speed 100
duplex full
no switchport
ip address 10.130.242.1 255.255.255.0
speed 100
duplex full
no switchport
ip address 10.130.244.1 255.255.255.0
speed 100
duplex full
no switchport
ip address 10.130.246.1 255.255.255.0
speed 100
duplex full
no switchport
ip address 10.142.40.97 255.255.255.252
description ### BCRS Switch 10.142.36.17 ###
no switchport
ip address 10.142.160.18 255.255.255.248
speed 100
duplex full
qos trust dscp
auto qos voip trust
tx-queue 3
   priority high
   shape percent 33
interface Vlan1
no ip address
shutdown
interface Vlan11
ip address 10.130.34.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan15
ip address 10.130.35.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan16
ip address 10.130.40.3 255.255.255.0
no ip redirects
standby 40 priority 110
standby 40 preempt
interface Vlan17
no ip address
shutdown
interface Vlan45
ip address 10.130.45.3 255.255.255.0
standby 45 priority 105
standby 45 preempt
interface Vlan66
ip address 10.130.66.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan67
ip address 10.130.67.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan68
ip address 10.130.68.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan69
ip address 10.130.69.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan70
ip address 10.130.70.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan71
ip address 10.130.71.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan72
ip address 10.130.72.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan73
ip address 10.130.73.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan74
ip address 10.130.74.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan75
ip address 10.130.75.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan76
ip address 10.130.76.3 255.255.255.0
no ip redirects
standby 10 preempt
interface Vlan128
ip address 10.130.128.2 255.255.252.0
no ip redirects
standby 128 priority 110
standby 128 preempt
interface Vlan166
ip address 10.30.66.3 255.255.255.0
standby 166 priority 105
standby 166 preempt
interface Vlan167
ip address 10.30.67.3 255.255.255.0
standby 167 priority 105
standby 167 preempt
interface Vlan168
ip address 10.30.68.3 255.255.255.0
standby 168 priority 105
standby 168 preempt
interface Vlan169
ip address 10.30.69.3 255.255.255.0
standby 169 priority 105
standby 169 preempt
interface Vlan170
ip address 10.30.70.3 255.255.255.0
standby 170 priority 105
standby 170 preempt
interface Vlan171
ip address 10.30.71.3 255.255.255.0
standby 171 priority 105
standby 171 preempt
interface Vlan172
ip address 10.30.72.3 255.255.255.0
standby 172 priority 105
standby 172 preempt
interface Vlan173
ip address 10.30.73.3 255.255.255.0
standby 173 priority 105
standby 173 preempt
interface Vlan174
ip address 10.30.74.3 255.255.255.0
standby 174 priority 105
standby 174 preempt
interface Vlan175
ip address 10.30.75.3 255.255.255.0
standby 175 priority 105
standby 175 preempt
interface Vlan176
ip address 10.30.76.3 255.255.255.0
standby 176 priority 105
standby 176 preempt
interface Vlan235
ip address 10.30.35.3 255.255.255.0
standby 235 priority 105
standby 235 preempt
interface Vlan247
ip address 10.130.247.2 255.255.255.0
no ip redirects
shutdown
standby 247 priority 110
standby 247 preempt
interface Vlan248
ip address 10.130.248.2 255.255.248.0
no ip redirects
standby 248 priority 110
standby 248 preempt
router eigrp 913
redistribute static
offset-list OFFSET out 1000000 GigabitEthernet6/24
network 10.130.34.3 0.0.0.0
network 10.142.36.13 0.0.0.0
network 10.142.160.18 0.0.0.0
no auto-summary
ip route 10.130.0.3 255.255.255.255 10.130.228.2
ip route 10.130.0.8 255.255.255.255 10.130.238.2
ip route 10.130.0.9 255.255.255.255 10.130.240.2
ip route 10.130.0.10 255.255.255.255 10.130.242.2
ip route 10.130.0.11 255.255.255.255 10.130.244.2
ip route 10.130.0.19 255.255.255.255 10.130.246.2
ip route 10.130.0.21 255.255.255.255 10.130.229.2 180
ip route 10.130.0.21 255.255.255.255 10.130.230.2 200
ip route 10.130.0.22 255.255.255.255 10.142.36.14
ip route 10.130.0.23 255.255.255.255 10.142.36.14
ip route 10.145.0.0 255.255.0.0 10.142.40.98 name Cloud_Traffic
ip route 10.145.0.0 255.255.0.0 10.142.160.17 100
no ip http server
permit 172.26.2.254
permit 10.152.6.240
permit 10.152.6.229
permit 10.152.6.230
permit 10.152.6.231
permit 10.152.6.236
permit 10.152.6.237
permit 10.152.6.238
permit 10.152.6.239
permit 10.152.6.232
permit 10.152.6.233
permit 10.152.6.234
permit 10.152.6.235
permit 10.152.12.30
permit 172.19.54.15
permit 172.19.55.15
permit 10.133.36.32
permit 10.133.30.29
permit 10.133.35.32
permit 10.133.31.30
permit 10.133.33.32
permit 10.133.30.30
permit 10.133.31.31
permit 172.19.52.31
permit 10.129.10.23
permit 10.134.34.15
permit 10.134.33.15
permit 10.134.35.9
permit 10.129.50.19
permit 10.152.12.52
permit 10.129.50.18
permit 10.133.54.21
permit 10.152.12.50
permit 10.129.50.20
permit 10.133.55.21
permit 10.152.12.51
permit 10.133.52.21
permit 10.133.53.20
permit 10.133.32.31
permit 10.133.32.30
permit 10.133.33.31
permit 10.133.37.30
permit 10.129.50.15
permit 10.152.12.40
permit 10.140.50.15
permit 10.130.39.20
permit 172.26.3.9
permit 172.26.103.9
permit 10.129.66.19
permit 10.129.67.18
permit 10.129.67.19
permit 10.129.66.18
permit 10.129.67.20
permit 10.129.66.50
ip access-list standard OFFSET
permit 10.130.0.8
permit 10.130.0.9
permit 10.130.0.10
permit 10.130.0.11
permit 10.130.0.3
permit 10.130.0.19
permit 10.130.45.0
permit 10.130.34.0
permit 10.130.72.0
permit 10.130.74.0
permit 10.130.69.0
permit 10.30.66.0 0.0.0.255
permit 10.30.67.0 0.0.0.255
permit 10.30.68.0 0.0.0.255
permit 10.30.69.0 0.0.0.255
permit 10.30.70.0 0.0.0.255
permit 10.30.71.0 0.0.0.255
permit 10.30.72.0 0.0.0.255
permit 10.30.73.0 0.0.0.255
permit 10.30.74.0 0.0.0.255
permit 10.30.75.0 0.0.0.255
permit 10.30.76.0 0.0.0.255
permit 10.30.35.0 0.0.0.255
permit 10.30.77.0 0.0.0.255
permit 10.30.36.0 0.0.0.255
permit ip any any
access-list 10 permit 10.145.0.0 0.0.255.255
tacacs-server key 7
control-plane
banner motd ^C
^C
line con 0
exec-timeout 5 0
password 7
logging synchronous
stopbits 1
line vty 0 4
exec-timeout 5 0
password 7
logging synchronous
length 0
line vty 5 15
exec-timeout 5 0
password 7
ntp clock-period 17179500
end
Hi Su Deok Eom,
I checked your configuration and everything looks fine. So at this point I would like to try and narrow down where the fault is happening. The first thing I would like to try is shutting down one of the ports in the channel-group 1 to see if we can determine if the issue stems from one of the links. My thought here is maybe the EIGRP hellos are hashing to a link in the bundle group that is bad (I know you checked the cables but there may be something else). I would shut Gi3/1 first on both sides, and see if EIGRP forms a neighbor relationship. If it doesn't, I would no shut Gi3/1 and repeat the test on Gi3/2. You can also try to ping 224.0.0.10 and source it from VLAN 11 while one of the interfaces is shut. This will tell you if the remote side is responding to the EIGRP multicast group.
I would also like to see a show version from the devices, so I can look into defects.
Anthony
moncy_cisco
hi,
Please provide me below outputs
Moncy K Thomas
