eigrp entries
carl_townshend
Am I right in saying eigrp feasible successors do not get installed into the routing table ?
kamal-learn
Level 4
Level 4
hi
not quit agree in all the cases, the best route is the successor is installed in the routing table, the backup routes are feasible successors normally are not installed in the routing table but as eigrp allows load balancing accross unequal cost paths, so with the use of the VARIANCE command you can arange your calculation so that it include the feasible successors as a possible route in the routing table, and you can make it appear in the routing table.
do rate if it does help
Carl,
By Default feasible successors are not installed in the routing table and are present only in the topology table.
Narayan
