EIGRP Implementation with GLBP
ALIAOF_
Level 11
Level 11
I'm in the process to install two 4948E switches.  I will be configuring GLBP and wanted to get some guidelines on configuring GLBP and EIGRP:
- First question is like HSRP I'm configuring it on both swithches like this:
Switch 1:
interface vlan 5
ip address 10.1.5.249 255.255.255.0
glbp 5 ip 10.1.5.1
glbp 5 priority 110
glbp 5 preempt
glbp 5 authentication md5 key-string xxxxxx
glbp 5 weighting track 5 decrement 20
Switch 2:
interface vlan 5
ip address 10.1.5.250 255.255.255.0
glbp 5 ip 10.1.5.1
glbp 5 priority 100
glbp 5 preempt
glbp 5 authentication md5 key-string xxxxxxx
- Second question is about EIGRP, when I configure EIGRP on the main switch that is AVG with the following commands, will I also have to run the same commands on the second 4948 E too?
router eigrp 10
network 10.1.5.0 255.255.255.0
Jon Marshall
Mohammed
Not sure exactly what your first question is ? You do indeed configure GLBP on both switches just as you would with HSRP. You do this with each vlan interface you want to run it on.
The EIGRP config will be needed on both switches. There is no direct relation between GLBP and EIGRP ie. whether or not the switch is the AVG is irrelevant as to the EIGRP config.
Jon
Jon Marshall
Mohammed
Jon
Thank you John ok that makes sense, now for the GLBP is it possible to setup a weight for certain VLAN's higher on one switch and certain VLAN's on the second for example:
Switch 1:
interface vlan 5
glbp 5 weighting 120
interface vlan 10
glbp 10 weighting 100
Switch 2:
Interface vlan 5
glbp 5 weighting 100
interface vlan 10
glbp 10 weighting 120
Adjust spanning tree accordingly i.e Switch 1 will be the root for VLAN 5 and Switch 2 will be the root for VLAN 10.
