01-11-2016 10:48 AM - edited 03-08-2019 03:22 AM
Hello
I have my Nexus 7000 connected via Eigrp to my 6500, I need to filter some Ip from the 6500 that I dont want to see in my network. how can i filter this in the Nexus?
thanks. !
Solved! Go to Solution.
01-11-2016 02:50 PM
ip prefix-list <NAME> deny 172.31.240.0/24
ip prefix-list <NAME> permit 0.0.0.0/0 le 32
int <x/y> <--- this connects to 6500
ip distribute-list eigrp Center prefix-list <NAME> in
where <NAME> is whatever you want.
Jon
01-11-2016 11:15 AM
You can use a distribute list.
Couple of points -
1) If the 6500 and Nexus are connected via a P2P link then you could configure the distribute list outbound on the 6500 to stop it sending certain routes to the Nexus switch or inbound on the Nexus switch to stop it receiving them.
Either would work.
If however the 6500 and Nexus are on a common vlan where the 6500 peers with other EIGRP neighbors then you should apply it inbound on the Nexus because the 6500 would still need to send those routes to it's other neighbors.
2) if you want to filter the majority of routes then you should write your acl or prefix list to only permit the specific routes you want.
If you want to accept the majority of routes then you should write your acl or prefix list to deny the routes you don't want and then accept the rest.
So you need to know which of the above it is.
Jon
01-11-2016 11:49 AM
Hello Jon
Thanks for you tips, can you tell me if this ir correct, just the code lines
IP access list Eigrp_Filter_Deny
10 permit ip 172.31.240.0 255.255.255.248 any
500 deny ip any any
int e1/2
ip port access-group Eigrp_Filter_Deny
thanks!
01-11-2016 11:58 AM
Is this for the Nexus switch ?
If so I believe you have to use a prefix list and not an acl.
So can you confirm if it is for the Nexus and I can help you out.
Also can you confirm that the only route you want the Nexus to receive from the 6500 is for 172.31.240.0/29 and not any others ?
Jon
01-11-2016 12:09 PM
I will apply this on the Nexus side.
Thanks.
01-11-2016 12:11 PM
I don't think you can because as I say I think you need to use a prefix list.
Can you reread my last post and answer the questions and then we can sort out the correct configuration.
Jon
01-11-2016 01:11 PM
Im having issue with config for this prefix, will this be ok?
ip prefix-list Eigrp_Filter_Deny seq 10 deny 172.31.240.0/24
ip prefix-list Eigrp_Filter_Deny seq 20 permit 0.0.0.0/24
int e1/47
ip distribute-list eigrp Center prefix-list Eigrp_Filter_Deny in
I got it to work.
Thanks.!
01-11-2016 01:19 PM
So is it working ?
The second line of your prefix list is not necessarily correct.
Jon
01-11-2016 01:35 PM
No is not working, after I add the first line I loose all inside eigrp.
01-11-2016 01:40 PM
Can you tell me exactly what you want to achieve.
Is it to deny 172.31.240.0/24 and then allow all other routes ?
Jon
01-11-2016 01:50 PM
yes I want to deny the 172 network via eigrp and allow al the other routes.
Thanks.!
01-11-2016 02:50 PM
Jon
01-11-2016 02:50 PM
It worked thanks!!!!!!
