EIGRP not send to neighbors changes in delay values
Hi people.
I need your help. I have a problem when a try to change de route of EIGRP.
When i insert the command delay 300 (for example) in the subinterface, i can see the change where type the command "show interface g0/1.xxx", in the line DLY 3000 usec. But, in the neighbors, allways see "Total delay is 20 microseconds"
Which can the cause?
I remember that work!!.
The neighbors are connected beetwen then through Lan-to-Lan.
I expect your answer.
Greeting
Have you check your K values?
Are you using redistribution at any point?
