eigrp routing metric
network770
I have this on my firewall facing the internet:
router eigrp 120
no auto-summary
network 192.168.10.0.0 255.255.255.0
redistribute static metric 1000000 1 255 1 1500
and that on my switch behind the firewall:
router eigrp 120
network 192.168.10.0 0.0.0.255
eigrp stub connected summary
i just got this config from an old employee.  can someone explain this to me?
I am seeing that the default gateway on the switch is the firewall and is learned from eigrp, what does this mean :
JohnTylerPearce
Level 7
Level 7
The 'redistribute static metric 1000000 1 255 1 1500' command is redistribute static routes into EIGRP with the default metric values of 1000000 1 255 1 1500. This Reads from left to right, Bandwidth, Delay, Reliability, Load, and MTU. 1000000 is the Bandwidth value, 1 is the delay value (1-255) so a delay is 1 is the least amount of delay you can have, 255 is the value of Reliability (1-255) so 1 is the best Reliability you can have, 1 is the load, (1-255), this means you have little load on this metric, 1500 is the MTU value.
The switch behidn the firewall is oboviously a L3 switch, and is setup as a EIGRP Stub Router, which is receving routes, but only advertising connected and summary routes to it's EIGRP neighbors within it's AS.
I hope that helped.
