EIGRP - switch acting like stub, but is not stub.
Topology:
Two routers, R1 (2951) and R2 (1921) are connected to a core stacked pair 3850.
Currently, only R2 has an active WAN connection. It is cellular running BGP. R1, Core, R2 all run EIGRP. R1 doesn't have anything on the other side of it. (R1 will soon have a microwave link out, running EIGRP)
Loopbacks - Core: 10.1.1.0/32    R1: 10.1.1.1/32   R2: 10.1.1.2/32
Core owns a few subnets and has routes to R1's loopback and R2's loopback and 0.0.0.0 just fine.
R2 has routes to everything EXCEPT loopback of R1.
R1 has routes only to Core's looback and subnets, doesn't have a 0.0.0.0.
All devices have their EIGRP neighbors established.
It looks for all the world like Core is operating as EIGRP stub, but stub is not in the config. What is going on here?
19 Replies 19
Philip D'Ath
Have you perhaps got an "IP Base" licence instead of "IP Services".  IP Base only enables EIGRP stub.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/qa_c67-722110.html
able 2.       Cisco IOS Software Feature Set Differences
Functions
LAN Base
IP Base
IP Services
Layer 2+
Enterprise access Layer 2
Wide range of Layer 2 access features for enterprise deployments supports Cisco StackPower technology
Complete Access Layer 2
Supports all Cisco Catalyst 2000 and Cisco Catalyst 3000 Layer 2 features, including hot standby protocols
Layer 3
Static IP routing support
Support for SVI
Enterprise access Layer 3
RIP, EIGRP stub, OSPF for routed access, PBR, IPv4 & IPv6 EIGRP stub routing, WCCP, IPV6 uRPF, IPV6 PBR, VRRPv3, Policy Classification Engine, HSRP v6
Complete access Layer 3
OSPF, EIGRP, BGP, IS-IS
VRF-lite
Sorry, I meant to post the license but forgot.
sho lic right-to-use
Slot# License name Type Count Period left
1 ipservices permanent N/A Lifetime
License Level on Reboot: ipservices
2 ipservices permanent N/A Lifetime
Perhaps try "no eigrp stub".
Are you using the older "router eigrp xxx" configuration or the newer "named" eigrp configuration method?
If you want to convert to the newer "named" eigrp configuration method check out the "eigrp upgrade-cli" command under "router eigrp xxx".
Was this switch always "ip services", or was it upgraded from a lower licence level?
IP Services out of the box.
Hello
sh ip protocols
sh ip route eigrp
sh ip eigrp neigbours
res
Paul
Kind Regards
Paul
Hi -
What makes you think that the core is acting like a stub?  Please post show commands that support your theory.
PSC
By "acting like a stub" I just meant that routes do not appear to be passed through the switch between the routers, but the switch's own routes are showing up on both routers. I'll get the other details in a bit.
Perhaps you would post the router eigrp config from all three devices? And also post show ip interface brief? This might give some insight into the issue.
Rick
Rick
R1
router eigrp 1
network 10.0.0.0
passive-interface default
no passive-interface GigabitEthernet0/0
no passive-interface GigabitEthernet0/1
no passive-interface GigabitEthernet0/2
GigabitEthernet0/0 10.1.2.138 YES NVRAM up up
GigabitEthernet0/1 10.1.1.130 YES NVRAM up up
GigabitEthernet0/2 10.1.1.134 YES NVRAM up up
Loopback0 10.1.1.1 YES NVRAM up up
CORE
router eigrp 1
network 10.0.0.0
no passive-interface GigabitEthernet1/0/1
no passive-interface GigabitEthernet1/0/24
no passive-interface GigabitEthernet2/0/1
no passive-interface GigabitEthernet2/0/24
GigabitEthernet1/0/1 10.1.1.129 YES NVRAM up up
GigabitEthernet1/0/24 10.1.1.137 YES NVRAM up up
GigabitEthernet2/0/1 10.1.1.133 YES NVRAM up up
GigabitEthernet2/0/24 10.1.1.141 YES NVRAM up up
Loopback0 10.1.1.0 YES NVRAM up up
R2
router eigrp 1
network 10.0.0.0
redistribute bgp xxxxx metric 10000 10 255 10 1500
distance eigrp 18 19
GigabitEthernet0/0 10.1.1.138 YES manual up up
GigabitEthernet0/1 10.1.1.142 YES manual up up
Cellular0/1/0 10.2.8.60 YES IPCP up up
Loopback0 10.1.1.2 YES manual up up
Tunnel12 10.2.12.60 YES NVRAM up up
On the core...
SHOW IP PROTOCOLS
*** IP Routing is NSF aware ***
Routing Protocol is "application"
Sending updates every 0 seconds
Invalid after 0 seconds, hold down 0, flushed after 0
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Maximum path: 32
Routing for Networks:
Routing Information Sources:
Gateway Distance Last Update
Distance: (default is 4)
Routing Protocol is "eigrp 1"
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP-IPv4 Protocol for AS(1)
Metric weight K1=1, K2=0, K3=1, K4=0, K5=0
Soft SIA disabled
NSF-aware route hold timer is 240
EIGRP NSF disabled
NSF signal timer is 20s
NSF converge timer is 120s
Router-ID: 10.1.1.0
Topology : 0 (base)
Active Timer: 3 min
Distance: internal 90 external 170
Maximum path: 4
Maximum hopcount 100
Maximum metric variance 1
Automatic Summarization: disabled
Maximum path: 4
10.0.0.0
10.1.1.142 90 1w5d
10.1.1.138 90 1w5d
10.1.1.134 90 1w5d
10.1.1.130 90 1w5d
SHOW IP EIGRP NE
EIGRP-IPv4 Neighbors for AS(1)
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
3 10.1.1.142 Gi2/0/24 14 1w6d 5 100 0 188
2 10.1.1.138 Gi1/0/24 11 1w6d 1 100 0 189
1 10.1.1.134 Gi2/0/1 10 1w6d 4 100 0 50
0 10.1.1.130 Gi1/0/1 10 1w6d 3 100 0 49
SHOW IP ROUTE (only showing a few relevant lines)
Gateway of last resort is 10.1.1.142 to network 0.0.0.0
D*EX 0.0.0.0/0 [170/258816] via 10.1.1.142, 1w5d, GigabitEthernet2/0/24
[170/258816] via 10.1.1.138, 1w5d, GigabitEthernet1/0/24
10.0.0.0/8 is variably subnetted, 27 subnets, 6 masks
D 10.1.2.136/30
[90/3072] via 10.1.1.134, 1w6d, GigabitEthernet2/0/1
[90/3072] via 10.1.1.130, 1w6d, GigabitEthernet1/0/1
D EX 10.1.1.0/22
[170/258816] via 10.1.1.142, 1w6d, GigabitEthernet2/0/24
[170/258816] via 10.1.1.138, 1w6d, GigabitEthernet1/0/24
D 10.1.1.1/32
[90/130816] via 10.1.1.134, 1w6d, GigabitEthernet2/0/1
[90/130816] via 10.1.1.130, 1w6d, GigabitEthernet1/0/1
D 10.1.1.2/32
[90/130816] via 10.1.1.142, 1w6d, GigabitEthernet2/0/24
[90/130816] via 10.1.1.138, 1w6d, GigabitEthernet1/0/24
On R2...
#SHOW IP PROTOCOLS
Maximum path: 32
Routing Protocol is "nhrp"
Maximum path: 32
Distance: (default is 250)
Redistributing: bgp 65282
Soft SIA disabled
Router-ID: 10.1.1.1
Topology : 0 (base)
Active Timer: 3 min
Distance: internal 18 external 19
Maximum path: 4
Maximum path: 4
10.0.0.0
10.1.1.141 18 1w6d
10.1.1.137 18 1w6d
10.1.1.129 18 5w1d
Routing Protocol is "bgp XXXXX"
IGP synchronization is disabled
Automatic route summarization is disabled
Unicast Aggregate Generation:
10.1.1.0/22 summary-only
Neighbor(s):
Address FiltIn FiltOut DistIn DistOut Weight RouteMap
10.2.12.1 WAN_IN
10.2.12.2 WAN_IN
Maximum path: 1
10.2.12.1 20 1w5d
10.2.12.2 20 1w5d
Distance: external 20 internal 200 local 200
#SHOW IP ROUTE EIGRP
Gateway of last resort is 10.2.12.1 to network 0.0.0.0
10.0.0.0/8 is variably subnetted, 23 subnets, 6 masks
D 10.1.1.0/32
[18/130816] via 10.1.1.141, 1w6d, GigabitEthernet0/1
[18/130816] via 10.1.1.137, 1w6d, GigabitEthernet0/0
D 10.1.1.128/30
[18/3072] via 10.1.1.141, 1w6d, GigabitEthernet0/1
[18/3072] via 10.1.1.137, 1w6d, GigabitEthernet0/0
D 10.1.1.132/30
D 10.103.177.0/24
D 10.103.178.0/24
#SHO IP EIGRP NE
(sec) (ms) Cnt Num
1 10.1.1.141 Gi0/1 13 1w6d 4 100 0 87
0 10.1.1.137 Gi0/0 12 2w0d 5 100 0 88
On R1...
#SHOW IP PROTOCOLS
Maximum path: 32
Router-ID: 10.1.1.1
Topology : 0 (base)
Active Timer: 3 min
Maximum path: 4
Maximum path: 4
10.0.0.0
10.1.1.133 90 1w6d
10.1.1.129 90 1w6d
1#SHOW IP EIGRP NE
(sec) (ms) Cnt Num
1 10.1.1.133 Gi0/2 11 2w0d 8 100 0 85
0 10.1.1.129 Gi0/1 13 2w0d 6 100 0 86
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 12 subnets, 3 masks
D 10.1.1.0/32
[90/130816] via 10.1.1.133, 2w0d, GigabitEthernet0/2
[90/130816] via 10.1.1.129, 2w0d, GigabitEthernet0/1
D 10.1.1.136/30
[90/3072] via 10.1.1.133, 2w0d, GigabitEthernet0/2
[90/3072] via 10.1.1.129, 2w0d, GigabitEthernet0/1
D 10.1.1.140/30
D 10.1.177.0/24
D 10.1.178.0/24
