04-20-2011 08:19 AM - edited 03-06-2019 04:43 PM
this is the output for sho ip route 10.35.29.0. Notice the distance is 90, and they type is internal
Routing entry for 10.35.29.0/24
Known via "eigrp 136", distance 90, metric 28674560, type internal
Redistributing via eigrp 136
Last update from 10.55.3.1 on Tunnel4, 4d00h ago
Routing Descriptor Blocks:
* 10.55.3.1, from 10.55.3.1, 4d00h ago, via Tunnel4
Route metric is 28674560, traffic share count is 1
Total delay is 1100100 microseconds, minimum bandwidth is 5000 Kbit
Reliability 255/255, minimum MTU 1400 bytes
Loading 6/255, Hops 2
This is the output for sho ip eigrp top 10.35.29.0/24 notice that both routes including the one to T4 are external, there are no internal routes in this topology output, so how is it that the route in my routing table is an eigrp internal route see next line, am I missing something, i feel like I should know this. I think that the route in the routing table should be to T0. Out of about 200 routes, only about 10 are like this, trying to figure out why.
D 10.35.29.0/24 [90/28674560] via 10.55.3.1, 4d00h, Tunnel4
EIGRP-IPv4 Topology Entry for AS(136)/ID(10.40.35.114) for 10.35.29.0/24
State is Active, Query origin flag is 1, 1 Successor(s), FD is 15898112
Waiting for 2 replies
Descriptor Blocks:
10.55.3.1 (Tunnel4), from 10.55.3.1, Send flag is 0x0, outstanding reply
Composite metric is (15898112/282112), route is External
Vector metric:
Minimum bandwidth is 5000 Kbit
Total delay is 601020 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1400
Hop count is 3
External data:
Originating router is 152.183.123.170
AS number of route is 1
External protocol is BGP, external metric is 0
Administrator tag is 3000 (0x00000BB8)
10.55.5.1 (Tunnel0), from 10.55.5.1, Send flag is 0x0, outstanding reply
Composite metric is (1818112/282112), route is External
Vector metric:
Total delay is 51020 microseconds
Load is 2/255
Minimum MTU is 1400
Hop count is 3
External data:
04-20-2011 09:23 AM
Mike
I am not sure what is going on. But here is what I observe. When you did the show ip route there was an entry in the routing table and so it's EIGRP state would be passive. When you did the shoe topology the EIGRP state is active. So what changed between the commands?
Rick
