EIGRP - VRRP
SP_UK_LEE
I am currently working on a project involving two Cisco routers running VRRP for a switch that connects to all our servers. The setup includes several IPsec tunnels on the master router to remote sites.
My concern arises from the configuration of EIGRP between the two routers. Despite configuring EIGRP, I have observed that the EIGRP routes are not being advertised to the backup router. I’m uncertain about the root cause of this issue and would appreciate your assistance in identifying and resolving it.
Any advice,it would be immensely helpful.
M02@rt37
Hello @SP_UK_LEE
possible to share configurations ?
Thanks.
Best regards
Note:-For any FHRP we config l3 between two peer' this make exchange of prefix and make l3 redundacy path.
Your issue both VRRP must advertise the prefix to all other l3 device  if one not advertise to other vrrp peer that can be from
1-you config passive interface
2-you config acl that drop eigrp
Check two points
MHM
