Eircom ISP & 837 Routter
shane.kearney
Hello guys, is there anyone in here that can help me with an issue that i am having trying to set up my new 837 router to Eircom ISP. I have got the settings but it does not work for me, is there anyone that can help with this problem?? please
Hi Mat,
I've used the config below with Eircom. You'll need to tidy up the NAT bits...
Kevin
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly
zone-member security Outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname eircom
ppp chap password 0 broadband1
ppp pap sent-username eircom password 0 broadband1
mat.pearsons
Eircom are fans of PPPoE rather than the PPPoA (Generally used) elsewhere in the UK, which is the biggest catch with them I find. There is a pretty good online config here:
http://www.alandoherty.net/cisco/eircom-dsl-with-esat-isdn-backup-config.txt
Courtesey of Alan Doherty.
However if you want to post your config up (less passwords) then I can take a look and see if I can spot the issue.
Mat
Hi Mat,
Kevin
interface ATM0/0/0
no ip address
pvc 8/35
interface Dialer0
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
