Email notification for Cisco switches through putty
Brahma E
Hi Team,
   I would like to add email to get all kind of alert notification for Cisco switches through putty .please help on this
10 Replies 10
marce1000
   - Not possible , putty is used for accessing the switches only , either through SSH or serial connection ,
 M.
@marce1000 tell me the process from both  through SSH or serial connection
 M.
@marce1000 I am asking procedure thorough ssh or serial connection as mentioned by you
what exactly are you trying to accomplish ? Are you trying to use Putty as an email recipient as described in the document linked below (in combination with an EEM script) ?
https://superuser.com/questions/245143/smtp-email-in-putty
@Georg Pauwen I would like to set up email notification for Cisco switch ,for which I need help
understood. I am not really clear on how and why you want to involve Putty ? The usual way of setting up email notifications (sourced from the switch) would be to configure EEM (as described in the example below)...
https://www.ciscozine.com/send-email-from-your-router-using-eem/?utm_content=cmp-true
@Georg Pauwen ,it seems you have given procedure for router ,I am asking to set email notification for Cisco switch
the procedure is generic and should work on switches as well. Did you try to configure the script on the switch ?
extsvc
Get email notification when someone try to login your Cisco Switch or Router
