Bookmark
Subscribe
2213
Embedded Packet Capture IE2000
Khalid El-Assal
is the  Embedded Packet Capture supported on IE2000 switches?
I see the command available on an IE2000 switch that is running a 15.X code but the I am not able to collect any packets when configuring the buffer and the capture point.
monitor capture buffer CB size 2000 linear
monitor capture point ip cef CP F1/1 both
monitor capture point associate CP CB
monitor capture point start CP
marce1000
   - Not sure , check if there is anything in the logs after the last (start) command has been given, you may get more info's.
 M.
