Embedded packet capture not capturing packets from outside LAN
dragojlo
HI all,
I have Catalyst 4500 L3 Switch and I am trying to capture some packets with EPC from outside my LAN but I see only packets coming from inside my network. I have configured my access list for EPC like this:
permit ip any host xx.xx.xx.x
permit ip host xx.xx.xx.x any
I want to see the packets for only one ip address. So when I ping ip address from my switch I see the packets coming. But when I try to ping it from outside my network nothing is coming. The IP address is definitely reachable from outside. I think the EPC is configured properly because I wouldn't see any packets at all. Does someone maybe know what might be the problem?
there are CEF and process switching,
remove the CEF from capture and check again (make the direction BOTH).
Thanks A Lot
MHM
8 Replies 8
Torbjørn
Is the 4500 performing NAT on the traffic?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
No, there is no NAT configured on the switch.
do you apply the packet capture control-plane IN or OUT direction ??
Thanks A Lot
MHM
I have set it to be both direction. Like this:
monitor capture point ip cef POINT vlan 45 both
I forgot to mention that it is a vlan interface but as I said the IP address is definitely reachable from outside so I don't know if it matters.
Thanks A Lot
MHM
I removed CEF and now I can see some packets from outside but they are not mine. When I ping and ssh to my host I still don't see that packets coming. Could a host somehow be blocking to see the packets? Thanks for help MHM, I am new to this and I am still learning.
Use from-us to check ping/ssh/telnet from SW or to SW.
Thank you for help
