ip device tracking in cisco 3850
Ibrahim Jamil
Level 6
Level 6
Hello Guys
where is the ip device tracking in cisco 3850 , new code , did they change the command
thanks
3 Accepted Solutions
Leo Laohoo
IP Device Tracking is available since 3.X.X.
Enable globally first and then enable on a per-interface next.
Ibrahim,
are you running a 16.x version ? They moved IPDT to SISF. The below is from the attached support document:
"If your device has no legacy IP Device Tracking (IPDT)  CLI configuration, you can only use the new SISF-based device-tracking CLI commands for all your future configuration. The old IP Device Tracking CLI are is not available."
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-1/configuration_guide/b_161_consolidated_3650_cg/b_161_consolidated_3650_cg_chapter_01001010.html#concept_A4AB227AC35840A1ACE51453EDBACD3E
conf t
ip device tracking
interface <BLAH>
ip device tracking max 10
end
sh ip device track interface <BLAH>
10 Replies 10
Leo Laohoo
Hello leo
it looks liek this now
device tracking policy TRK
int X/X
device-tracking attach-policy TRK
pls advide
Ibrahim
Ibrahim,
conf t
ip device tracking
interface <BLAH>
end
Thanks to all of you guys
i've the same problem, WS-C3850-12S (MIPS) running 16.12.08 if try to configure ip device tracking i'm promped this error:
usa-sw1-mid(config)#ip device tracking probe auto-source override
% Invalid input detected at '^' marker.
usa-sw1-mid(config)#ip device tracking probe delay 10
even configuring it at interface level:
usa-sw1-mid(config-vlan)#int Gi1/0/1
usa-sw1-mid(config-if)#ip device tracking maximum 0
could you please advise me?
tachavez
This one is already resolved, but, if you are using IOS-XE 16.X the command required is:
ip device tracking probe...
Reference:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-1/command_reference/b_161_consolidated_3650_cr/b_161_consolidated_3650_cr_chapter_01110.html
saagar
To enable IP Device Tracking on a Cisco Catalyst 3850, you could use the following commands in interface configuration mode:
interface <interface_type> <interface_number>
ip device tracking
For example, if you want to enable IP Device Tracking on a GigabitEthernet interface, you would enter:
interface GigabitEthernet1/0/1
ip device tracking
If you're not finding the ip device tracking command in the new code or if the command structure has changed in the software version you're using, I recommend referring to the Cisco documentation specific to your software version or reaching out to Cisco's technical support or community forums for the most up-to-date information on how to enable IP Device Tracking in your particular version of the Catalyst 3850 software. Command variations and syntax changes can occur in different software versions and updates, so it's important to consult the documentation that matches your specific environment.
hi,
i found the cisco document about this version: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-12/command_reference/b_1612_3850_cr/m_1612_sec_cr.html#wp3659447134
but i don't understand how to adapt the commands.
it's written to give the "
device-tracking upgrade-cli
but it's not clear if this command will allow me to give the
i
For consistency purposes, IP Device Tracking (IPDT) is implemented in two different ways.
1.  If IPDT was used when the switch was previously on 3.X.X, then the command "ip device tracking" is valid.  Upgrade to 16.X.X and the command to use is still "ip device tracking".
2.  If IPDT was never used in 3.X.X, then the new 16.X.X command is "device-tracking database".
