10-21-2021 12:28 PM
Dear all,
I'am trying to add FEX FABRIC to my N9K 9396 PX.
I'have plugged port 1 on N9K and port 1 fiber to N2K 2248TP.
I'have also do configuration on my N9K but I can't see interfaces of the N2K, but I see N2K.
N9K-PAR-2(config-if)# show interface fex-fabric Fabric Fabric Fex FEX Fex Port Port State Uplink Model Serial --------------------------------------------------------------- 101 Eth1/1 Configured 1 N2K-C2248TP-E-1GE FOX1924H7MR N9K-PAR-2(config-if)#
fex 101 pinning max-links 1 description "N2K"
interface Ethernet1/1 switchport mode fex-fabric fex associate 101
"Show fex detail" return anything.
N9K-PAR-2(config-if)# sh logging last 30 2021 Oct 21 21:18:57 N9K-PAR-2 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/1 is down(Config change) 2021 Oct 21 21:18:59 N9K-PAR-2 %ETHPORT-5-SPEED: Interface Ethernet1/1, operational speed changed to 10 Gbps 2021 Oct 21 21:18:59 N9K-PAR-2 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/1, operational duplex mode changed to Full 2021 Oct 21 21:18:59 N9K-PAR-2 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/1, operational Receive Flow Control state changed to off 2021 Oct 21 21:18:59 N9K-PAR-2 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/1, operational Transmit Flow Control state changed to off 2021 Oct 21 21:18:59 N9K-PAR-2 %ETHPORT-5-IF_UP: Interface Ethernet1/1 is up in Layer3 2021 Oct 21 21:19:51 N9K-PAR-2 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/1 is down(Config change) 2021 Oct 21 21:19:53 N9K-PAR-2 %ETHPORT-5-SPEED: Interface Ethernet1/1, operational speed changed to 10 Gbps 2021 Oct 21 21:19:53 N9K-PAR-2 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/1, operational duplex mode changed to Full 2021 Oct 21 21:19:53 N9K-PAR-2 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/1, operational Receive Flow Control state changed to off 2021 Oct 21 21:19:53 N9K-PAR-2 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/1, operational Transmit Flow Control state changed to off 2021 Oct 21 21:19:53 N9K-PAR-2 %ETHPORT-5-IF_UP: Interface Ethernet1/1 is up in mode access 2021 Oct 21 21:19:57 N9K-PAR-2 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/1 is down(Config change) 2021 Oct 21 21:19:59 N9K-PAR-2 %ETHPORT-5-SPEED: Interface Ethernet1/1, operational speed changed to 10 Gbps 2021 Oct 21 21:19:59 N9K-PAR-2 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/1, operational duplex mode changed to Full 2021 Oct 21 21:19:59 N9K-PAR-2 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/1, operational Receive Flow Control state changed to off 2021 Oct 21 21:19:59 N9K-PAR-2 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/1, operational Transmit Flow Control state changed to off 2021 Oct 21 21:19:59 N9K-PAR-2 %ETHPORT-5-IF_UP: Interface Ethernet1/1 is up in mode access 2021 Oct 21 21:21:16 N9K-PAR-2 %ETHPORT-5-IF_DOWN_CFG_CHANGE: Interface Ethernet1/1 is down(Config change) 2021 Oct 21 21:21:18 N9K-PAR-2 %ETHPORT-5-SPEED: Interface Ethernet1/1, operational speed changed to 10 Gbps 2021 Oct 21 21:21:18 N9K-PAR-2 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/1, operational duplex mode changed to Full 2021 Oct 21 21:21:18 N9K-PAR-2 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/1, operational Receive Flow Control state changed to off 2021 Oct 21 21:21:18 N9K-PAR-2 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/1, operational Transmit Flow Control state changed to off 2021 Oct 21 21:21:24 N9K-PAR-2 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 1 of Fex 101 that is connected with Ethernet1/1 changed its status from Created to Configured 2021 Oct 21 21:21:24 N9K-PAR-2 %ETHPORT-5-IF_DOWN_INITIALIZING: Interface Ethernet1/1 is down (Initializing) 2021 Oct 21 21:21:26 N9K-PAR-2 %ETHPORT-5-SPEED: Interface Ethernet1/1, operational speed changed to 10 Gbps 2021 Oct 21 21:21:26 N9K-PAR-2 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/1, operational duplex mode changed to Full 2021 Oct 21 21:21:26 N9K-PAR-2 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/1, operational Receive Flow Control state changed to off 2021 Oct 21 21:21:26 N9K-PAR-2 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/1, operational Transmit Flow Control state changed to off 2021 Oct 21 21:21:26 N9K-PAR-2 %ETHPORT-5-IF_DOWN_NONE: Interface Ethernet1/1 is down (None) N9K-PAR-2(config-if)#
Anyone have an idea ? I really need to configure this FEX FABRIC for my customer.
Thanks !
Axel
Solved! Go to Solution.
10-21-2021 01:49 PM
watch the short video below...
10-21-2021 01:49 PM
10-21-2021 01:50 PM
Hello
Thanks. I'have resolved my issue : i'have not created port-channel, i'have only put FEX fabric config on a port.
FEX was not in love of that.
