Emergency NAT question
poulid
Hello. Is it possible to have the following entry in a nat config using pools?
ip nat pool ras 199.43.3.207 199.43.3.207 prefix-length 24
ip nat inside source list 101 pool ras overload
access-list 101 deny ip 199.43.3.206 host 198.20.10.121 log
access-list 101 permit ip any host 198.20.10.121 log
Will this nat everything going to 198.20.10.121 except 199.43.3.206? I am looking to exclude this address from natting, and have it go straight there, but nat every other subnet behind it.
mohmmad.imran
It is not claer wht you exctly want to achieve
AFAI can understand that you want to NAT all traffic comning from 198.20.10.0 network and and you specifically want any traffic from source 198.20.10.121 will not be natted by your router.
ip nat inside source list 1 pool ras overload
access-list 1 deny ip 198.20.10.121
access-list 1 permit ip 192.20.10.121 0.0.0.255
Sorry to be so vague. I want traffic going to 198.20.10.121 to be natted and show up as 199.43.3.207, except if it is coming from 199.43.3.206.
Darnel,
Your configuration looks good and should achieve your task.
Sundar
