emulation with GNS3
i'm usig GNS3 and i have to deal with this situation:
R5 has NM-1FE-TX modul (connected to R4).
R5 has also NM-16ESW modul (connected to R1,R2 and R3).
here are the config :
R4 :
interface FastEthernet0/0
ip address 190.1.1.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet2/0
ip address 190.1.2.1 255.255.255.0
duplex auto
speed auto
no ip http server
no ip http secure-server
ip classless
ip route 191.1.1.0 255.255.255.0 190.1.1.2
ip route 191.1.1.0 255.255.255.0 190.1.2.2
R5:
ip dhcp excluded-address 191.1.1.1 191.1.1.10
ip dhcp pool URNE
   network 191.1.1.0 255.255.255.0
   default-router 191.1.1.1
ip address 190.1.1.2 255.255.255.0
duplex auto
speed auto
ip address 190.1.2.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/11
switchport access vlan 10
interface FastEthernet1/12
interface FastEthernet1/13
interface Vlan10
ip address 191.1.1.1 255.255.255.0
R1 :
ip address dhcp
duplex auto
speed auto
R2 :
ip address dhcp
duplex auto
speed auto
R3 :
ip address dhcp
duplex auto
speed auto
R1#ping 190.1.1.1
Sending 5, 100-byte ICMP Echos to 190.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/30/52 ms
R1#ping 190.1.2.1
Sending 5, 100-byte ICMP Echos to 190.1.2.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/42/68 ms
R2#ping 190.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/39/68 ms
R2#ping 190.1.2.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/39/60 ms
R3#ping 190.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/38/72 ms
R3#ping 190.1.2.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/32/72 ms
EVREY THING IS FINE :
now i will shutdown interface f0/0 of R5:
R5(config)#interface f0/0
R5(config-if)#sh
R5(config-if)#end
R5#
*Mar  1 00:24:58.887: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 00:24:59.799: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
R5#
*Mar  1 00:25:00.799: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
And i ping from routers R1, R2 and R3 190.1.2.1 (other link :(f2/0-----f2/0)).
R1#ping 190.1.2.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/32/64 ms
R2#ping 190.1.2.1
Success rate is 0 percent (0/5)
why R2 can't ping and R1 can ?
R3#ping 190.1.2.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/53/84 ms
this is correct but to really get sure your IP SLA probes go out f0/0 you  should do this:
access-list 199 permit icmp any host 190.1.1.2
route-map SLA
match ip add 199
ip local policy route-map SLA
Alain
cadet alain
on R4 f0/0 is still UP( that's GNS3 behaviour) and so both routes stay in the routing table of R4 and if R4 decided to forward the traffic out this interface then it is failing. You should implement tracking with IP SLA on your first  static route on R4 and it will delete the route from the routing table when R5 next-hop is unreachable and it will only have one route and so one interface to send the replies and it will work.
Alain
is this correct ?
ip sla monitor 1
type echo protocol ipIcmpEcho 190.1.1.2 source-interface FastEthernet0/0
frequency 5
ip sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
ip route 191.1.1.0 255.255.255.0 190.1.1.2 track 1
ip route191.1.1.0 255.255.255.0 190.1.2.2 254
route-map SLA
match ip add 199
Alain
thank you  very much ,you saved me
