enable controller e1 and serial 0/0 on cisco 1841
yeow28
i am unable to configure controller e1 interface on a new cisco 1841 router.
i am trying to configure a serial interface but the option is not there too.
IOS - Version 12.4(15)T7
what could be the reason ?
yourname(config)#contro
yourname(config)#
i do not see the controller options there.
5 Replies 5
smothuku
Level 7
Level 7
Did you check the IOS which is present in router supports controller command.
Can you send us show run output.
Satish
don't you first have to enable the card?
card type e1 0 0 (if it's in slot 0/0)
smothuku
Level 7
Level 7
Below images supprots T1/ E1 options.
12.4(11)XW9 c1841-ipbasek9-mz.12.4-11.XW9
12.4(11)XJ4
c1841-ipbasek9-mz.12.4-11.XJ4
12.4(6)XE3
c1841-ipbasek9-mz.12.4-6.XE3
12.4(2)XA
c1841-ipbasek9-mz.12.4-2.XA
12.4(22)T
c1841-ipbasek9-mz.12.4-22.T
12.4(21a)
c1841-ipbasek9-mz.12.4-21a
12.3(11)YZ2
c1841-ipbase-mz.12.3-11.YZ2
Cheers ,
Satish
managed to solve the problem after i add
card type e1 0 0
then the controller option appears
controller e1 0/0/0.
didnt know that i need the card type option.
yes indeed, as I thought (see above)
If you insert for example a VWIC, you first need to enable the card
