enable embedded wlc catk9
CSCO12550173
hi there,
i want to test the embedded wlc that comes with the cat9k
the model of the switch is:
Switch Ports Model SW Version SW Image Mode
* 1 40 C9300-24UX 16.9.2 CAT9K_IOSXE INSTALL
i'm trying to install it via this command
request platform software package install switch all file flash:cat9k-wlc.16.09.02.SPA.pkg verbose
but i'm getting this error, thhere is a guide or configuration guide to make this and see how the embedded wlc
works with the wlc
FAILED: Expected directory /tmp/sw/spa for running SPA software tree
[1]: Finished install failed on switch 1
Checking status of install on [1]
[1]: FAILED: install failed in switch 1
SUCCESS: Finished install: Success on []. Failed on [1]
Ensuring that cached content is written to media
... cached content flushed to media
---------------------------version
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.9.1r [FC2], RELEASE SOFTWARE (P)
(CAT9K_LAB-DNA uptime is 17 minutes
Uptime for this control processor is 18 minutes
System returned to ROM by Reload Command
System image file is "flash:packages.conf"
Last reload reason: Reload Command
Leo Laohoo
Embedded WLC on Catalyst 9K isn't supported (yet).
First supported release is 16.11.0.
