enable multicast on 2950/2960 series switches
zappo0305
How do you enable multicast traffic on 2900 series switches?
Reza Sharifi
2950 is a layer-2 switch.  You need command
ip igmp snooping vlan vlan-id
here is the config guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_6_ea2c/configuration/guide/swgigmp.html
8 Replies 8
JohnTylerPearce
Level 7
Level 7
try 'ip multicast-routing'
routing on a layer 2 switch?
Thanks Reza
2950 won't do routing.
2960, however, can.  You'll need to upgrade the switch to 12.2(55)SE3 and later.
Reza Sharifi
Reza you're making me feel stupid lol....
No worries John. With so many different product lines and switch series Cisco has, some times it is confusion what devices do layer-2 and what do layer-3, what IOS works with what platforms and features set.
It is all good
Reza
