ENABLE SSH on 3750g series switch
srikanth ath
Level 4
Level 4
hi all
iam looking to access my switch (3750g series VER: 12.2(35) SES) through ssh service  . but couldnt as when iam looking to generate a RSA key pair it prompted like UNRECOGNISED COMMAND.
i went through the cisco articles and found that all 3750g series switch supports ssh service.
these all the commands i tried out , but everything vein, my company asking me to access switch through ssh. how should i do it now?
wavel3#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
wavel3(config)#
wavel3(config)#
wavel3(config)#cry?
% Unrecognized command
wavel3(config)#crypto ?
wavel3(config)#host ?
  WORD  This system's network name
wavel3(config)#hostnam
wavel3(config)#hostname wavel3
wavel3(config)#cry
wavel3(config)#cry
wavel3(config)#cry?
wavel3(config)#cry
wavel3(config)#ip ssh?
wavel3(config)#ip ssh ?
wavel3(config)#crypto key generate rsa
% Invalid input detected at '^' marker.
wavel3(config)#line vty 0 4
wavel3(config-line)#transp
wavel3(config-line)#transport input ?
  all     All protocols
  none    No protocols
  telnet  TCP/IP Telnet protocol
how to enable ssh to my switch
are there any thoughts.
thanks in advance
srikanth
18 Replies 18
cadet alain
Can you post sh ver output.
if you've got a k9 image it should work.
Regards.
Alain.
this is output for ssh .. i have tried everywr to enable but if i try to type ssh it prompts like unrecognised command
..1..initial part is my switch supports ssh
  2. if it supports how to enable it ( i have tried with this command in config mode..  crypto key generate RSA)
switch3#sh ip ssh version ?
switch3#sh ip ssh ?
switch3#sh ip ssh ?
switch3#sh ip ssh  ?
switch3#sh ip ssh
any kind of help please
thanks
srikanth
Post the sh ver | i IOS output as I asked above.
Alain.
hi alain
here is my sh ver output..
and i just came to know i should download cryptographic software image from cisco.  is this is the problem if so
1. where can i download
2. how to install it in to the switch
3. help me out with clear config steps.
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5, RELEAS
E SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01080000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWA
RE (fc1)
switch3 uptime is 46 minutes
System image file is "flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE
5.bin"
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision H0) with 118784K/12280K
bytes of memory.
Processor board ID FOC1503V6EM
Last reset from power-on
8 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : C0:62:6B:9C:CB:00
Motherboard assembly number     : 73-10219-09
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC150274K6
Power supply serial number      : AZS1504011R
Model revision number           : H0
Motherboard revision number     : A0
Model number                    : WS-C3750G-24TS-S1U
System serial number            : FOC1503V6EM
Top Assembly Part Number        : 800-26859-03
Top Assembly Revision Number    : C0
Version ID                      : V05
CLEI Code Number                : COMB600BRA
Hardware Board Revision Number  : 0x09
Switch   Ports  Model              SW Version              SW Image
*    1   28     WS-C3750G-24TS-1U  12.2(35)SE5             C3750-IPBASE-M
Configuration register is 0xF
thanks and regards
srikanth
this is indeed the problem, you haven't got a k9 image.
You'll have to download a valid IOS image from Cisco to a tftp or ftp server.
Then you'll have to verify you have enough space in flash to upload the image to flash.
If space is ok then you can do a copy ftp:// / path to image   flash: or the same with tftp.
If ftp then configure ftp password and username: ip ftp password and ip ftp user in global config.
Then ask system to boot from this image with the bootsystem  flash:   command.
Once it is working you can delete the old IOS and remove the bootsystem command.
Regards.
Alain.
hi alain,
got confused in searching the ios image .. there are number of ios . but which of them should i have to download which supports ssh service to my switch(3750g version :12.2(35) ). if u could please help me with this, i will be really thankful to you.
the ipbasek9-12.2(35)SE1 to SE5 support ssh.
Alain.
Srikanth and Alain,
Every image that contains the string k9 in its name should support SSH. The k9 designates that the image supports crypto features including SSH.
Best regards,
Peter
Hi Peter,
I just cited these versions so he doesn't downgrade version but keeps the same or upgrade he he can but with a k9 image.
Regards.
Alain.
Hello Alain,
Certainly so. I am not correcting you I just thought that it is fairly simple to know whether an image supports crypto operations simply by looking at its name, so I've added that remark.
Best regards,
Peter
hello guys
i have downloaded ADVANCED IP SERVICES WITH WEB BASED DEV MGR
c3750-advipservicesk9-tar.122-35.SE5.tar   will this gonna work out to use ssh service and all layer 3 +layer 2 functions
thanks for your time u have helped me a lot
regards
srikanth
Srikanth
You originally had IPBase so you should download the IPBASE image with a k9 in the image name.
If you download Advanced IP Services and you previously had IP BASE you need to pay for the upgrade.
Jon
Srikanth,
Do not forget to mark this thread as answered - Alain has precisely identified the source of your problem and provided you with a correct solution.
Best regards,
Peter
Hi Peter,
Thanks for all you're doing for the community.
Regards.
Alain.
