Enable store and forward on Cisco Switch
h5emu1234
Hi all,
Got bad link and need to enable a switch for store and forward on all interfaces. I am using a Cat 2950 using IOS 12.1what do I need to do to get this working. I know the command syntex "switching-mode store-and-forward" every time I use the command I get %unrecognised.
glen.grant
  As far as I know there is nothing you need to configure for this , that is what the switch uses
as its switching method and is not configurable .
Ganesh Hariharan
Hi all,
All Catalyst switches use store and forward except the Nexus switches, as  switch  buffers and, typically, performs a checksum on each frame before forwarding it on to ports.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Mr Bartlett
Would changing from cut-through switching to store-and-forwarding cause downtime if in live production?
