Enabling a Fast Ethernet port in 2950
kumaranchn
The status of the fast ethernet port is showing err-disabled.So I need to enable a port in cisco 2950 switch.Kindly let me know how to proceed.
ankbhasi
Hi Friend,
You can simply shut and unshut the port and it will come up. But it is better to find out what is the reason for the interface going into errdisable state.
Can you check the logs and see if it tells you the reason? If logs does not show you you can configure errdisable detect command to detect the reason.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_20_ea2/command/reference/cli1.html#wp3227150
Also this is the link to configure erridsbale recovery
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_20_ea2/command/reference/cli1.html#wp2946661
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Friend,
Ankur
Thanks !!.It works.
issue the following commands for example for Fa 0/1
Switch#
configure terminal
interface Fa 0/1
no shut
end
Shaheen
*****Sorry Ankur....i saw your post after posting mine. Your links are very helpful and rated accordingly. People like you make these forums very useful. thanks
