Enabling Jumbo frames
yves.haemmerli
Level 5
Level 5
Hi all,
We have to enable Jumbo Frames on two Catalyst 3750X-48T-S Stacks.
Could someone tell me if the operation will be transparent (no traffic disruption) ?
Thank you in advance
Reza Sharifi
On the 3750x series switches you can enable Jumbo frame without traffic disruption, but in order for it to take effect you have to reboot the stack.  So, this should be done in a maintenance window as rebooting the stack will cause disruption.
Reza Sharifi
Thank you Reza for your fast answer !
