Enabling Netflow on 6506 Switchport
davidhuynh5
Please review the attachment. I have the netflow baseline configured, but can't enable it on Fa4/48. This there a different command?
Samlpe link or sample configuration would be greatly appreciated. Thanks.
Haris P
Level 4
Level 4
Try the below commands
ip route-cache flow
ip flow ingress
I hope the below link will help with the config
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080721701.shtml#ennetflow
You need to configure the port like below to be able to sent stats to netflow server.
interface FastEthernet4/48
description juniper_ssg550; 10.25.96.254; lan0
bandwidth 45000
load-interval 30
switchport
switchport access vlan 96
switchport mode access
ip flow ingress
You must enable only ip flow ingress or ip flow egress as per best practices.
If you enable both on single interface then the data will club and give you improper results like club all the data incoming and out going like that.
Please rate the helpfull posts.
Naidu.
