Enabling PCAnywhere From outside to inside
amiralisetoudeh
Hi everyone,
I'm trying to configure our router to enable someone from outside (internet) to be able to PCAnywhere to a PC in the LAN.
The PC has an internal IP of 10.10.10.10, and the external IP of the router is, for example, 60.60.60.60
I believe I have to configure a static NAT to accomplish this task - but I'm not sure which command set I have to use.
Would it be:
ip nat inside source static
or
ip nat outside source static?
Could someone show me the full command I'd have to execute?
Al
Not applicable
From memory you need two port mappings
ip nat inside source static tcp 10.10.10.10 5631 interface Dialer1 5631
and
ip nat inside source static udp 10.10.10.10 5632 interface Dialer1 5632
hope this helps
