Enabling rapid-pvst in cat 6513
jorgeacat
I can not  enable to rapid- protocol in catalyst 6513, does not support for it, only support pvst
Someon how can i enable to rpvst? You know if is necessary to upgrade IOS, it has
s72033_rp-ENTSERVICESK9_WAN-M - 12.2(18)SXF9 IOS. The cisco software Advisor could not localized the features fot this IOS.
Do you have some advices?
tks.
InayathUlla Sharieff
Hi Jorge,
Can you please let me know what you get when you type "spanning-tree mode ? " on your device from config mode?
Here is the procedure to configure the RPVST+
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00807b0670.shtml
Inayath
