Enabling SDM routing for PBR on Cisco 3750 in stack
Erico Verissimo
Hello everyone,
I have a question about enabling SDM on SW 3750 in stack system. The question is..How can I enable the SDM on stack Switches? Do I need enabling on both switches or only on stack-wise virtual switch?
Thanks in advance.
Moh Mogh
Hello Erico,
If the switches are already stacked, then you will only need to enable on the master.
If they are not, after the switches become stacked, the master template will be overridden.
You can take a look at the following links for more information:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/44921-swdatabase-3750ss-44921.html#topic4
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_53_se/configuration/guide/3750xscg/swsdm.html#wp1101007
Mohammad
Moh Mogh
Hello Erico,
Mohammad
Erico Verissimo
Hello Mohammad,
Thank you so much for your response, this document is so useful.
Érico
