Enabling ssh on a switch
waridtel.com
Can anybody tell me how to enable ssh on a switch or a router if you have ssh compatible IOS.
Best Regards,
Asim
Amit Singh
Asim,
here you go :
http://www.cisco.com/warp/public/707/ssh.shtml
HTH,
-amit singh
glen.grant
Basically it is give it a domain name , then do a conf t , "crypto key generate rsa, hit enter select the key size when it asks then allow ssh on your vty lines coming in. If you are not using AAA authentication like tacacs then you must create a local username and password . If you are using AAA then this step is not needed.
