Enabling ssh with a startup config on C2960 and C3560CG Switches
renemerki1
Im am currently testing the new features of IOS 150-2.SE5 with SmartInstall
Is there a way to bring the IP SSH Key in the backup-config that after restoring the SSH Key is in the Switch ?
I've seen a "kron" in a forum but it was not working for my System:
kron occurrence crypto_key in 2 oneshot
policy-list crypto_key
kron policy-list crypto_key
cli event manager run crypto_key
event manager applet crypto_key
event none sync yes
action 1 cli command "enable"
action 2 cli command "config t"
action 3 cli command "crypto key generate rsa modulus 2048"
action 4 cli command "exit"
action 5 cli command "write mem"
action 6 cli command "end"
I've tried without action.... nothing worked for me.
Box I want to store/restore
WS-C2960CG-8TC-L -> c2960c405ex-universalk9-mz.150-2.SE5
WS-C3560CG-8PC-S -> c3560c405ex-universalk9-mz.150-2.SE5
many thanks for your help
kind regards
René
Leo Laohoo
Just put the command "crypto key generate rsa modulus 2048" into the configuration template and it should be fine.
This is how I've done my SmartInstall.
Hi leo
i am not using a config template, it is the file from backup. I use smart install for a replacement solution in a running network.
the switches perform an backup with a kron job every sunday night.. And if one fails the customer can replace the switch by himself and it get the own config back on the switch,.
so i will not use a config template
kind regards
 rene
Hi all,
I got now the solution from TAC:
I'm using WS-C2960CG-8TC-L andWS-C3560CG-8PC-S Switches
CONFIG:
VSTACK-DIRECTOR
conf t
no vstack script flash:post_install.txt
vstack group custom NR32 connectivity
no script flash:post_install.txt
--> Be sure you've deleted all pre-installed txt files.
tclsh
puts [open "flash:GENERATE_RSA_KEYS.tcl" w+] {
ios_config "crypto key generate rsa modulus 2048 general-keys"
tclquit
VS-Director#show flash: | i tcl
61 65 Mar 09 2016 06:05:06.0000000000 +00:00 GENERATE_RSA_KEYS.tcl
conf t
tftp-server flash:GENERATE_RSA_KEYS.tcl
end
no scripting tcl init flash:config.text
CLIENT
kron policy-list EXECUTE_SCRIPT
cli tclsh tftp://10.162.78.26/GENERATE_RSA_KEYS.tcl
kron occurrence UPON_BOOTUP in 00:01 oneshot
GOE-AC-nr32-1#show crypto key mypubkey rsa
% Key pair was generated at: 03:29:32 MEST Mar 30 2011
Key name: GOE-AC-nr32-1.novelis.biz
Key type: RSA KEYS
Storage Device: not specified
Usage: General Purpose Key
Key is not exportable.
Key Data:
30820122 300D0609 2A864886 F70D0101 01050003 82010F00 3082010A 02820101
9F020301 0001
% Key pair was generated at: 03:29:35 MEST Mar 30 2011
Key name: GOE-AC-nr32-1.novelis.biz.server
Key type: RSA KEYS
Temporary key
Usage: Encryption Key
Key Data:
307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00A8E571 F2146ADB
It was working perfect.
kind regards
René
Glenn Martin
Moving post to the appropriate forum. for faster response, please ensure you create the post in the correct forum.
Glenn
SMB Community Manager
