Enabling SSO also enables NSF?
guillermo.ruiz
I have SSO enabled on my 6509E, but I'm not sure if NSF is enabled.
Maybe I am a little confuse  to understand what is NSF helper and NSF aware that my switch displays, as follows:
switch#sh ip ospf nsf
Routing Process "ospf 1"
IETF NSF helper support enabled
Cisco NSF helper support enabled
switch#sh ip prot
*** IP Routing is NSF aware ***
Someone can provide some help?
guruiz
Reza Sharifi
NSF-aware if it is running NSF-compatible  software. A device is said to be NSF-capable if it has been configured  to support NSF; therefore, it would rebuild routing information from  NSF-aware or NSF-capable neighbors.
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/gr_ospf.html
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You enable NSF in the routing protocol, if supported.
For example:
router ospf 100
nsf
thanks Reza,  thanks Joseph,
Your answers are so kind and helpful.
I only have a doubt about NSF helper, do you know what is this?, due it is enabled before I configure NSF under OSPF.
guruiz
You don't need to
All you have to do enable NSF under OSPF on all the routers that are NSF aware.
