Encapsulated vlan from distro not seen by Gateway border router.
Hi all,
i have replaced a gateway router model 7206 running as a router on a stick that is using ISL encapsulation with a newer model router 3925e, the new router has a vlan250 encapsulated on a sub interface, i use that sub interface as source for authentication for tacacs+, the problem is with the new router i can't ping vlan250 ip address on the distro switch, at the same time i can't see the ip address of f the gateway router for vlan 250 in the arp table of the distro switch, mean while same configurations work with no issue with the old router model 7206.
any idea about what is causing this issue ?
Sahir
5 Replies 5
cadet alain
Can you post config of the 3925 as well as the one for switchport on the distro switch where the 3925 is linked.
Alain
here is the configs:
1-
3925e:
! No configuration change since last restart
version 15.1
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname gateway-is1
boot-start-marker
boot-end-marker
!card type command needed for slot 1
logging buffered informational
aaa new-model
aaa authentication login default group tacacs+ line enable none
aaa authorization exec default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name wan.er.com
redundancy
ip ssh time-out 60
ip ssh version 2
interface Loopback0
 ip address 10.26.5.13 255.255.255.255
 no ip mfib cef input
 no ip mfib cef output
interface GigabitEthernet0/0
 description distro-2.4/41.x.x
 ip address 10.26.255.238 255.255.255.248
 duplex full
 speed auto
interface GigabitEthernet0/1
 description distro-1.4/41.x.x
 ip address 10.26.255.246 255.255.255.248
 duplex full
 speed auto
interface GigabitEthernet0/2
 description distro-1.4/38.x.x
 no ip address
 duplex full
 speed auto
interface GigabitEthernet0/2.150
 description iSIT A Public Zone
 encapsulation isl 150
 ip address 10.26.150.1 255.255.255.0
 no ip redirects
interface GigabitEthernet0/2.218
 encapsulation isl 218
 ip address 10.26.218.1 255.255.255.0
 no ip redirects
interface GigabitEthernet0/2.236
 encapsulation isl 236
 ip address 10.26.236.6 255.255.255.0
 no ip redirects
 standby 236 preempt
 bridge-group 1
interface GigabitEthernet0/2.250
 encapsulation isl 250
 ip address 10.26.250.201 255.255.255.0
 no ip redirects
interface GigabitEthernet0/2.550
 no ip redirects
interface GigabitEthernet0/2.570
 description iSIT C Public Zone
 encapsulation isl 570
 ip address 10.26.70.1 255.255.255.0
 no ip redirects
interface GigabitEthernet0/2.590
 description iSIT E Public Zone
 encapsulation isl 590
 ip address 10.26.90.1 255.255.255.0
 no ip redirects
interface GigabitEthernet0/3
 description etc-sitdistro-2.4/38.x.x
 no ip address
 duplex full
 speed auto
interface GigabitEthernet0/3.160
 description iSIT B Public Zone
 encapsulation dot1Q 160
 ip address 10.26.160.1 255.255.255.0
 no ip redirects
interface GigabitEthernet0/3.228
 encapsulation dot1Q 228
 ip address 10.26.228.1 255.255.255.0
interface GigabitEthernet0/3.580
 description iSIT D Public Zone
 encapsulation dot1Q 580
 ip address 10.26.80.1 255.255.255.0
ip forward-protocol nd
ip pim bidir-enable
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.26.255.241
ip route 0.0.0.0 0.0.0.0 10.26.255.233
ip route 10.19.189.0 255.255.255.0 192.168.100.86
ip route 12.34.246.16 255.255.255.248 192.168.100.86
ip tacacs source-interface GigabitEthernet0/2.250
logging source-interface GigabitEthernet0/2.250
logging 10.20.250.59
2-  7206
distro-1#show run int gig1/1/18
Building configuration...
Current configuration : 308 bytes
interface GigabitEthernet1/1/18
 description gateway-is1.f3/0.x.x
 switchport
 switchport trunk encapsulation isl
 switchport trunk allowed vlan 150,218,236,250,570,590
 switchport mode trunk
 speed 100
 duplex full
 storm-control broadcast level 1.00
 rmon collection stats 1118 owner monitor
end
the posted configs look correct.
Can you post sh ip int br | i Vlan250 on Distro switch
I suppose the default gw for vlan 250 is GigabitEthernet0/2.250 IP ?,
if not post a diagram and note the IP of this default gw.
Alain
yea, GigabitEthernet0/2.250 is the GW for that vlan
here is the show show command on the distro switch.
show ip int br | i Vlan250
Vlan250                10.26.250.5     YES NVRAM  up                    up
Any idea about what might be causing the issue ?
