end device able to get wireless connection but unable to get IP
tyr668
hi guys , i've made sure that my DHCP has been set on the interface connected. DHCP is working for my Access point and PCs, but keep getting errors for laptop connected wirelessly. any advice? packet tracer has been attached if there's any reference needed
Turn2
Quick guess- because your VLAN 10 is on a different IP network than your DHCP server which could be the problem. You need to make them on the same network, or configure DHCP helper on the switch.
doesn't seem like the problem even after i've tried amending the commands as said
Can you post the latest setup?
