Enforcing Minimum Password Length on switches, routers, and FWs
Khagler24
Cisco sent a letter addressing the lack of ability in enforcing a minimum password length on IOS devices and ASAs. In the letter, Cisco states that "With the shipping versions of Cisco IOS as of the current date, the native capabilities allow for encrypting the password as well as specifying a minimum length."
In regards to specifying a minimum length, I believe Cisco is referring to Autosecure for routers. But I don't know of any way to set a minimum password length on switches, even though Cisco states that it is natively support by IOS. I also know of no way to do this with ASAs. I know we can enforce several policies with TACACS, but we're looking for device IOS capabilities.
I'd also like to know what is meant by a "shipping version" of IOS. I'd always thought that a device came with a base IOS with a base license.
Thanks for the time and help.
2 Accepted Solutions
With "shipping version" the newest available versions are ment. If you don't use them, some of these fancy new features can't be used.
For the ASA:
asa(config)# password-policy ?
configure mode commands/options:
  authenticate-enable  Enable the user authentication feature
  lifetime             Set password lifetime
  minimum-changes      Set minimum character changes between old and new
                       password
  minimum-length       Set minimum password length
  minimum-lowercase    Set minimum number of lowercase password characters
  minimum-numeric      Set minimum number of numeric password characters
  minimum-special      Set minimum number of special password characters
  minimum-uppercase    Set minimum number of uppercase password characters
IOS-Router:
router(config)#security passwords min-length ?
  <0-16>  Minimum length of all user/enable passwords
For the Catalyst I'm not aware of a corresponding setting. But the best option is to let the TACACS-server control these settings.
p.mcgowan
Level 3
Level 3
you can set password min-length by using the following command;
Full details of the command can be found here;
http://www.cisco.com/en/US/docs/ios/12_3t/secur/command/reference/sec_s1gt.html#wp1204059
Please rate post if helpful
5 Replies 5
For the ASA:
                       password
IOS-Router:
Thanks karsten for your time and knowledge. This is exactly what I was looking for.
p.mcgowan
Level 3
Level 3
I have a Cisco  9200L switch running IOS XE version 16.12.4 and the command for setting the minimum password length is not present.
NBS-BT-ICT-C9200L(config)#security ?
% Unrecognized command
How can set the password length?
I checked all command references up to the latest Bengaluru (17.6.x) release, there is no command to set the minimum password length, unfortunately...
